<outputparams> <param name="task_dbf" label="Output dbf file" required="true" type="datafile" visible="true"/> </outputparams>
<outputparams> <param name="task_dbf" label="Output dbf file" required="true" type="recordset" visible="true"/> </outputparams>
Thanks for your response. I was thinking that but I am not sure how I am suppose to do this. This is coming from a model that is being published and when I publish it makes it "GPRecordSet" without me doing anything. How do I go about changing it to "GPDataFile"? I am not sure if the model has to be changed or this is a publishing option. Thanks,
Thanks, my issue is my parameter in model builder is listed as "Table" and not as "File" and I can't really find a tool that can give me a parameter type "File" from my output table. I know I must be missing something but any help to this specific issue would be great.
Right click your tool in ArcCatalog and go to properties, then go to the parameters tab.
