Hi I am from Papua New Guinea, importing xy excel data to 10.2 was ok, however, when exporting to shp.file, arcmap crash, please I need some help here...Thanks
What procedure/tool were you using?
Firstly, I simply add the xy excel data from File menu, add data than add xy data.
It was ok, however, when i want to export this excel data to shp, the software crashed.
So let me guess, you right-clicked on the layer, then selected Data, Export Data and specified a filename and it crashed? Or was there something else you did? Do the fieldnames conform to what is required? Any further information?
Yes that was what happened, further my file name was a single word so am not sure what the problem might be. Will shortly be upgrading to 10.2.2, mean while I really would appreciate any help in rectifying this issue.
did you specify a complete filename and path ie. c:\temp\myshapefile.shp or did you just type in a word
The excel data was one word, located on my desktop and when added to the map, arcmap crashed instantly
see my suggestion above...desktops are the last place I would save anything
