map.on("layers-add-result", function (results) {
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/nihilo/nihilo.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <link rel="stylesheet" href="css\MyMobileMaps.css"> <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.9/js/dojo/dojox/layout/resources/FloatingPane.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/layout/resources/ResizeHandle.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <script src="http://js.arcgis.com/3.8/"></script>
packages: [{ "name": "agsjs", "location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load }]
"dojo.fx",// needed if use jsapi 3.0 "esri.arcgis.utils", "dijit.form.ToggleButton", "dijit.TitlePane"
The AMD version of connect is on, like this:map.on("layers-add-result", function (results) {
I tried this but still not getting anything: map.on("layers-add-result", function (results) { //alert("Test") var standardTOC = new agsjs.dijit.TOC({ map: map //noLegend: true }, 'standardDiv'); standardTOC.startup(); //alert("test2") var sliderTOC = new agsjs.dijit.TOC({ map: map, layerInfos: [ { noLayers: true, showGroupCount: true, layer: flMCY_Stores_Regions, title: "Macy's Stores District"}, { noLayers: true, layer: flMCY_Stores, title: "Macy's Stores Region", }, { noLayers: true, layer: dlDRegionDistrictPolygons, title: "Boundary Files", slider: true } ], style:'inline' }, 'sliderDiv'); sliderTOC.startup(); }); //map.addLayers([dlDRegionDistrictPolygons]); map.addLayers([dlDRegionDistrictPolygons,flMCY_Stores,flMCY_Stores_Regions,dlMCY_Stores]);
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/nihilo/nihilo.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <link rel="stylesheet" href="css\MyMobileMacysMaps.css"> <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.9/js/dojo/dojox/layout/resources/FloatingPane.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.9/js/dojo/dojox/layout/resources/ResizeHandle.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.min.js" type="text/javascript"></script> <script> var dojoConfig = { parseOnLoad: true, packages: [{ "name": "agsjs", "location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load }] }; </script> <script src="http://js.arcgis.com/3.9/"></script> <script type="text/javascript" src="bookmarks/District_bookmarks.js"></script> <script type="text/javascript" src="bookmarks/Store_bookmarks.js"></script> <script src="jsfiles\Real_Estate_Filters.js"></script>
require([ "esri/map", "esri/graphic", "esri/tasks/FindTask", "esri/tasks/FindParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/Color", "dojo/on", "dojo/dom", "dijit/registry", "dojo/_base/array", "dojo/_base/connect", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore", "dijit/form/Button", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojox/widget/TitleGroup", "dijit/layout/AccordionContainer", "dijit/layout/TabContainer", "esri/dijit/Bookmarks", "esri/dijit/LocateButton", "esri/dijit/HomeButton", "esri/dijit/BasemapGallery", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/dijit/Measurement", "esri/dijit/InfoWindowLite", "esri/InfoTemplate", "agsjs/dijit/TOC", //Floating Panel "dojox/layout/FloatingPane", "dojox/layout/Dock", "dojox/layout/ResizeHandle", "dojo/dnd/move", "esri/tasks/query", //"esri.symbols.SimpleMarkerSymbol", //Datagrid "dojo/data/ItemFileWriteStore", "esri/tasks/QueryTask", "dojo/_base/Color", "esri/Color", "dojo/_base/connect", "dijit/dijit", "dojo/fx", "esri/arcgis/utils", "dijit/form/ToggleButton", "dijit/TitlePane", "dojox/form/CheckedMultiSelect", "dojo/domReady!" ], function( Map, Graphic, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Font, TextSymbol,Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser, BorderContainer, ContentPane, TitleGroup, AccordionContainer, TabContainer, Bookmarks, LocateButton, HomeButton, BasemapGallery, ArcGISDynamicMapServiceLayer, FeatureLayer, Measurement, InfoWindowLite, InfoTemplate, TOC, FloatingPane, Dock, ResizeHandle, move, query, ItemFileWriteStore, QueryTask, Color, ESRIColor, connect, dijit,fx, utils, ToggleButton, TitlePane ) {
