Hi,I tried to download "Arc Hydro" through 2.Third party SFTP client, because I have a lot of problems with the "Catchments (Catchement Polygon Processing) " (the application keep frozen).And I used: User: ADSRiverHydraulics Password: ADSRiver.2014 and is not working, does someone changed the password???(also I have tried to download with Filezilla:sftp://mft.esri.comADSRiverHydraulics ADSRiver.2014 22and it doesn't work)Anyone can help me? V.
Based on the number of posts describing problems accessing the software, your repeated stance that everything is fine as it is can be debated.
My previous post was addressed to folks who have stewardship of this data and the mft access portal. It was not addressed to you.
Does the current version of ArcHydro work with 10.2.2?
Note that ArcHydro Tools (current 10.2.0.40 for ArcGIS 10.2/10.2.1/10.2.2) has already been downloaded into a local system folder.
Terry,Sorry, no insult intended--just being realistic, you alone seem to have the issue with this community service as provided by Esri. A half dozen users with transitory issues connecting to the MFT service is hardly a crisis.Perhaps, but really not much point for you to complain to a project support forum when a simple PM would get you direct answers from Esri.Suggest that you contact Esri Professional Services - Water Resources Team at archydro@esri.comChristine Dartiguenave monitors that email address and would likely answer for the team.Alternatively, you could directly contact Dr. Dean Djokic -- ddjokic@esri.com, it is his team.Might be worth the effort as despite a functional repository with viable MFT delivery, Esri Professional Services might be willing to make other arrangements to support you and your fellow users at the U.S. Department of the Interior.Regards,Stuart
Note the new password for the ftp site as of 03/11/2014:User login: ADSRiverHydraulicsPassword changed to: ADSRiver.2014Christine DartiguenaveEsri Water Resources Team
I cannot login. I am using filezilla.
The problem is that the site will get locked for a while if the wrong password is used too many times.
It should unlock in a little while. As an alternative, you can go the following location for download. Both locations are synchronized.
http://downloads.esri.com/archydro/archydro
Manish Shrivastav,
Just verified that the MFT site is up and functional, please verify your sftp configuration as at the top of this thread--and try again.
Alternatively, the Water Resources Team has put up an HTTP service here. As announced by Christine in Alternate Download Location for Arc Hydro Setup Files
Stuart
Is there a tutorial or instruction manual to go with the ArcHydro Tools_x64 from your ftp site? This is the first time I have downloaded it, so I have a bit of learning curve. I'm using ArcGIS 10.2.
Thanks!
Sarah
