I realize this thread is not new, however I did not see a resolution. I have the identical problem. It was working in 10.1 but on switching to 10.2 it stops responding during Packaging of Process.
Kevin,
Having the same problem with my ArcGIS Server 10.2.2. Can not publish any GP Services that I have created in model builder, if I publish the results from a toolbox (no model) works fine.
I can get the service to publish if I use the staging draft service (which does get created before the crash) and then use the server system tools to >Stage Service > Upload Service.
Perplexing.
Danny
I resolved this issue by uninstalling ArcFM Desktop. Publishing now works without the errors I was receiving.
Thank you for the information Daniel.
That's the first time in this thread that has been brought up (ArcFM being installed).
Looking through our system, I found this logged as NIM096880. We do not currently have a fix, but is something we're investigating.
I wonder if installing patch 593 for the ArcFM Object Reader will resolve this particular problem? ArcFM Solution 10.2.1 Patch #593
Thanks for this,
Really struggling to understand why this would start happening now (as it was working previously but recently added FME desktop 2015 which may include ArcFM Object Reader components. Will check and confirm here.
Edit, we don't have anything to do with ArcFM Object Reader as far as I can see.
The server simply will not allow the GP python toolbox that runs perfectly fine on desktop to be published as a GP service (or even SD file).
Regards,
Ben
If you want to install ArcFM Object Reader 10.2 with ArcGIS Server 10.2/10.2.1/10.2.2 and also want to publish your models or custom tools successfully, then you also need to install ArcFM server 10.2. I have tried it and successfully pulished my custom models as geoprocessing service.
If you do not have ArcFM Server Installation Files, then you will need to remove ArcFM Object Reader from your system.
Publishing Geoprocessing services need ArcGIS Server 10.2/10.2.1/10.2.2 alone on a machine or with ArcFM Object Reader 10.2 and ArcFM server 10.2.
Why this happens, I also do not know...
