The theme options have been missing in the Custom Web App Builder. They are only missing in new custom web apps, when I go to edit an older one, the options are there.
Are there any errors presented in the "Web AppBuilder for ArcGIS" console window?
Hi Robert, thanks for asking. No, I am not currently seeing any errors. I am using organization themes but they have not produced a problem before. It is confusing though because the error is only present when building new apps but is not present when opening apps that are even a couple of months old.
Maybe the new AGOL update changed a parameter?
David,
I personally have not seen that issue. Without some error message to go off of, the only advice I can give is to call esri tech support.
Thanks Robert. That is why I posted here, so hopefully someone from ESRI can respond.
Posting on GeoNet is not a support option. You need to call esri tech support.
Thank you for reaching out! Below are some questions I have for you:
I look forward to your response!
Joe
Hi Joe and thank you for your email.
To answer your questions:
The last web app that I built that did not have the issue was on March 12
The issue first appeared on a web app that I built on May 13
Thanks!
Thank you for the response!
I just loaded up Microsoft Edge (build 41.16299.1004.0) and did not have any issues accessing the themes of a new Web AppBuilder in ArcGIS Online. Since you only have access to one browser, something I'd recommend would be to login to ArcGIS Online at home or on a different wifi to see if you notice any difference in functionality.
Is there any way you'd be able to get access to Chrome or Firefox in your work environment?
Cheers,
Joe,
I'm now having the same issue as David has described. Previously, I have used the Web AppBuilder before with no issues but now (the second web app I'm putting together) the themes won't show up.
I'm operating on Chrome right now, let me know if there are any resolutions to this issue. In the meantime I will continue trying things to get this to work.
Justin
