Do u need a different views for Folders & Files in Document Library???????
I did lot of finding for your query and got this. Try it, it may be useful for you.....msdn.microsoft.com/en-us/library/ee231579.aspx
Hello,I am facing the same problem and I can reproduce this behavior.Can someone from ESRI clarify if this is a known bug?Thank you!Carsten
Hello All,Yes, I can confirm that this is a bug with the ArcGIS SharePoint Map Web Part. Items in folders should work, as you've pointed out. I'll add this to our internal bug queue.Thanks,Katy
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
