old thread but i thought i would post my answer as it does not require an existing map doc
this does assume that you have arcMap installed and not just arcpy. but who is using arcpy w/o having ArcMap installed?
map_file = r'c:\test\test_map..mxd'
# open and close a file
open(map_file,'r').close()
# open the file with default application
os.startfile(map_file)
# sleep for a couple minutes to allow the file to be fully opened
time.sleep(120)
# kill the application in a pretty violent way yet not corrupting the file.
os.system("taskkill /im arcmap.exe /f")
# work with yout map
mxd = arcpy.mapping.MapDocument(map_file)
Not so much a workaround as much as a conscious decision...
import arcpy import os arcpy.env.workspace = r"c:\data\file.gdb" my_mxd = arcpy.mapping.MapDocument(r"c:\path\to\my.mxd") data_frame = arcpy.mapping.ListDataFrames(my_mxd)[0] # Switch to data view my_mxd.activeView = data_frame.name # Load standard layer with symbology, append to TOC in first data frame my_layer = arcpy.mapping.Layer(r"c:\path\to\some.lyr") arcpy.mapping.AddLayer(data_frame, my_layer, 'TOP') # Loop through rasters in workspace, swap out layer's source with raster's for fcname in arcpy.ListRasters(): # Full path to raster new_raster = os.path.join(arcpy.env.workspace, fcname) # Set layer's source my_layer.dataSource = new_raster # Zoom to extent df.extent = arcpy.Describe(new_raster).extent # Save to disk my_mxd.saveACopy("c:\\output\\out_%s.mxd" % fcname)
my_layer.replaceDataSource(arcpy.env.workspace, 'RASTER_WORKSPACE', fcname[:-4])
Old thread, but I just used your code although I had to change 'r' to 'w+' in third line. Is this due to changes in python since 2014? I don't understand how your code could work because with the open function in 'read' mode it could not create the file.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
