Hi. I couldn't find any solution to the below described problem in the forum. Please let me know if there is a such thread or if you know how to solve it.I have checked the "Overwrite the output of geoprocessing operations" in the Tools->Options->General window in ArcMAP 9.3.1. But when I am runing the same model second time, I am getting an error message: ERROR 000210: Cannot create output... If I am manually removing the output files generated from the first run, the model works fine. But again for the next run it gives the same error. It seems that the "Overwrite the output of geoprocessing operations" parameter is not haveing any influence. Please let me know if you have any idea what is wrong here.Thanks in advance.
Hi Dave. Sorry for late response (I forgot to change the notification option to email.)The help page you have mentioned is not helping. I have admin rights on the computer and I am the only person using it. The address is correct. When I am changing the output files name for each runs it is working fine.The model is quite simple. It uses only Select by location and Copy tools. See how model looks in the attachment.ThanksHarut
Why is it important to specify that ModelBuilder “overwrite the outputs of geoprocessing operations”?
because if you don't you have to provide new file names at every run of the model... not so bad when it is designed to work, but a real pain when you are testing a model and you just want to reuse a particular name instead of flooding your computer with spurious useless files.
Since this thrr3ead is long demised, perhaps you could start a new thread and pose a question that conveys your situation and why you are interested in an answer and what you have tried and the results you found
