Yes, absolutely, the CONNECTIONS parameter controls the number of total connections (sum of app server and Direct Connect). You can update the value with the 'sdeconfig' utility or by correctly updating the row in SDE.SERVER_CONFIG. - V
C:\>set SDEUSER=xyz C:\>set SDEPASSWORD=***** C:\>set SDEINSTANCE=5153 C:\>sdeping -c 80 -v +DELAY 17:10 ArcSDE 9.3 Connection Test Utility Thu Jun 10 17:05:23 2010 ------------------------------------------------------------------------ Server: YYYYY Instance: 5153 Database: eval93 Username: xyz RDBMS: PostgreSQL Version: 9.3.1 Description: PostgreSQL Build 2784(PostgreSQL) Build Date: Tue Oct 27 10:51:14 2009 Release: 93005 Connections: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Connect Delay: 333.33 ms (avg) Connect Stats: 312.00 ms (min) / 656.00 ms (max) / 69.32 ms (stddev) Connection attempt 25 failed -- Error: Operation Failed (-1) Disconnecting: 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
