In ArcGIS Online, when adding a csv file from a URL (Add Layer from Web), the system doesn't recognize the columns, it only shows _html_. But my csv file contains the following columns: FID, ISO-3166 alpha-2, NS deployed
Sébastien,
Take out the hyphens and spaces. Put in underscores for your field names.
ISO_3166_alpha_2, NS_deployed
I agree with Adrian, you need to remove any spaces or special characters from the columns in the excel and try and have the columns names to start with a letter and not a number.
Hi Adrian,
Thank you very much for your feedback.
We did try as you said but still the same message show up. It might come from our Share Point (linked to some security process). We are enquiring on our side. We will let you know when we find a solution.
Best regards
Can you share the CSV layer publicly here so others can test it?
Unfortunately the file is on our Share Point Organization, I cannot share it. I can send it to you if you'd like to test it. But it looks like that (saved as csv) :
Do you have location data for it to be located on the map?
This article may help:
CSV, TXT, and GPX files—ArcGIS Online Help | ArcGIS
