Graphics tab was not available in the Insert tab, so I had to customize the ribbon to add it. But when I tried to insert a picture, it wouldn't work.
Hi Bob,
If I understand your issue correctly you are saying that you are trying to insert a picture element onto a layout and you do not see the Graphics group (circled in red below) in the Insert tab of the ribbon.
Is this correct?
Tom
I customized the ribbon and added the Graphics tab to the Insert tab so I could insert pictures. But adding pictures doesn’t work. A Blueish box appears in the lower left and I am unable to drag a rectangle to add the picture.
Bob Charles
Tribal Transportation Program Manager
Knik Tribe
P.O. Box 871565
Wasilla, Alaska 99687
Direct (907) 373-3153
Cell (907) 306-2503
“A calm and modest life brings more happiness than the constant pursuit of success combined with constant restlessness.” Albert Einstein, Theory of Happiness 1922
This message is intended only for the use of the individuals to which this e-mail is addressed, and may contain information that is privileged, confidential and exempt from disclosure under applicable laws. If you are not the intended recipient of this e-mail, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this e-mail in error, please notify the sender immediately and delete this e-mail from both your "inbox" and your “deleted items” folders. Thank you.
Bob,
Which view are you trying to add a picture to? Layout? Map?
If it is to a Layout View why do you need to add the Graphics Group to the ribbon since it should already be there, if it was not manually removed through customization. If for some reason the Picture button, or the entire Graphics group, is missing from the Insert tab with an active layout this may be a bug and should be reported to Esri Support. They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
If you added the insert Picture to the Map View... this is not supported. To show pictures on the map (in geographic space) you will need to create a point feature class. Create point in the map location where you want the picture to appear and symbolize the point with picture marker symbol (see Marker symbol layers—ArcGIS Pro | ArcGIS Desktop).
For more information on working with graphics (including pictures) in the Layout View please refer to Add and modify graphics and text—Layouts | ArcGIS Desktop .
