I am attempting to use the insert cursor on an SDE connection and v10 sp3 doesn't seem to help, no row is added. Perhaps I am doing something else incorrectly?
import arcpygdb = 'Database Connections/gdb.sde' #change this to your GDB table = arcpy.CreateTable_management(gdb, 'testCursor') arcpy.AddField_management(table, 'testField', "TEXT") cur = arcpy.InsertCursor(table) row = cur.newRow() row.testField = 'insertedTextFromCursor' cur.insertRow(row) del cur del row
This was a bug that we fixed at 10.0 SP3. If you are attempting to use insert or update cursors against versioned data and they are not working, please try installing SP3.
I've actually been using SP3 for a while. I've decided to just to my edits in a file geodatabase and then just replace all the rows in the SDE table on a weekly basis with Delete and Append.
Still having issues 3 years later at 10.4.1. I'm trying to use an update cursor on an sde versioned database. Here's a test script:
streetCLInput <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\brandon_edits.sde\oki.sde.StreetCL'</SPAN> workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\brandon_edits.sde'</SPAN> <SPAN class="keyword token">import</SPAN> arcpy arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>streetCLInput<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'streets'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ChangeVersion_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"streets"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TRANSACTIONAL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"brandon_edits.brandon"</SPAN><SPAN class="punctuation token">)</SPAN> edit <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>workspace<SPAN class="punctuation token">)</SPAN> edit<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN> edit<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'streets'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'objectid'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'suffix'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'objectid = 11040'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">''</SPAN> cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> edit<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Script Complete'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The script crashes at line 10, but its because of line 5. Comment out line 5 and the script works, except the edits are made to the default version.
Here's another script basically copied and pasted from here : http://pro.arcgis.com/en/pro-app/arcpy/data-access/editor.htm with edits to change the version.
<SPAN class="keyword token">import</SPAN> arcpy fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\brandon_edits.sde\oki.sde.StreetCL'</SPAN> workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\brandon_edits.sde'</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'streets'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#arcpy.ChangeVersion_management("streets", "TRANSACTIONAL", "brandon_edits.brandon")</SPAN> <SPAN class="comment token"># Start an edit session. Must provide the workspace.</SPAN> edit <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>workspace<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Edit session is started without an undo/redo stack for versioned data</SPAN> <SPAN class="comment token"># (for second argument, use False for unversioned data)</SPAN> edit<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Start an edit operation</SPAN> edit<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Insert a row into the table.</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"streets"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> icur<SPAN class="punctuation token">:</SPAN> icur<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'New Test'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Stop the edit operation.</SPAN> edit<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Stop the edit session and save the changes</SPAN> edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The script "works" with line 5 commented out except again the edits are made to the default version. With line 5 uncommented, the script fails.
So how do you edit an sde versioned dataset with arcpy and not edit the default version? Any help would be much appreciated. (I'm starting to think the versioning is more hassle than its worth.)
I found the problem, in Catalog, the connection to the versioned data was using the default version as the transactional version to automatically connect to. To change this, you need to change the geodatabase connection properties to point to the version you wish to edit by default. It's a little confusing and odd that the default behavior is to edit the parent version of the version you are connected to but whatever. Its working now.
I still think the above script should execute without having to edit any geodatabase connection properties.
Also see this: BUG-000101529 : The 'Make Feature Layer' geoprocessing tool fails when 64-bit Background Geoprocessing is utilized with ArcGIS 10.4.1. when using a sde database connection. Potentially fixed at 10.5.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
