[Bindable] public var MainMap:Map [Bindable] public var layerROVGraphics:GraphicsLayer;
private var popData:DataPopup = new DataPopup; PopUpManager.addPopUp(popData,this,false,PopUpManagerChildList.POPUP); popData.MainMap = MainMap; 'MainMap is the <esri:Map> id popData.layerROVGraphics = layerROVGraphics; 'this is a graphics layer with a MouseEvent.ROLL_OVER event listener attached to each graphic
private function onMouseOver(event:MouseEvent):void { var graphic:Graphic = Graphic(event.target); for each (var attributes:Object in popData.dataGrid.dataProvider) { if (attributes["OBJECTID"] == graphic.attributes["OBJECTID"]) { popData.dataGrid.selectedIndex = (popData.dataGrid.dataProvider as ArrayCollection).getItemIndex(attributes) } } popData.dataGrid.scrollToIndex(dataGrid.selectedIndex)
private function onItemRollOver(event:ListEvent): void { highlightedGraphic = findGraphicByAttribute(event.itemRenderer.data, layerROVGraphics); // code to make the graphic glow } private function findGraphicByAttribute(attributes:Object, graphicLayer:GraphicsLayer):Graphic { for each (var graphic:Graphic in graphicLayer.graphicProvider) { if (graphic.attributes["OBJECTID"] == attributes["OBJECTID"]) { return graphic; } } return null; }
private function showGridResults(event:MouseEvent):void{ if(!myfloatdg){ var myfloatdg:QueryBuilderWidgetFloatDG; myfloatdg = QueryBuilderWidgetFloatDG(PopUpManager.createPopUp(map,QueryBuilderWidgetFloatDG,false)); PopUpManager.centerPopUp(myfloatdg); myfloatdg.dProvider = QBData.dataProvider; }else{ PopUpManager.addPopUp(myfloatdg,map,false); PopUpManager.centerPopUp(myfloatdg); } }
private function onItemRollOver(event:ListEvent):void { var gr:Graphic = findGraphicByAttribute(event.itemRenderer.data) gr.symbol = highlightSymbol; QBData.selectedIndex = findInList(gr); // gr.symbol = sfs;
if (myfloatdg){ if(myfloatdg.datagrid.dataProvider) myfloatdg.datagrid.dataProvider.removeAll(); myfloatdg.csvName = _csvName; myfloatdg.dgColumns = gridFields; myfloatdg.dProvider = fset.attributes; myfloatdg.graphicslayer = mqGraphicsLayer; // myfloatdg.zoomScale = zoomScale; myfloatdg.ownerWidget = QBWidget; } }
private function onMouseOver(event:MouseEvent):void { var graphic:Graphic = Graphic(event.target); for each (var attributes:Object in myfloatdg.datagrid.dataProvider) { if (attributes["ID"] == graphic.attributes["ID"]) { myfloatdg.datagrid.selectedIndex = (myfloatdg.datagrid.dataProvider as ArrayCollection).getItemIndex(attributes) } } myfloatdg.resultsGrid.scrollToIndex(QBData.selectedIndex) }
TypeError: Error #1009: Cannot access a property or method of a null object reference. at Function/oitt/private:onQueryResult/runQuery() at oitt/onQueryResult() at mx.rpc::AsyncResponder/result() at com.esri.ags.tasks::QueryTask/handleExecute() at Function/http://adobe.com/AS3/2006/builtin::call() at com.esri.ags.tasks::BaseTask/handleResult() at Function/com.esri.ags.tasks:BaseTask/esri_internal:sendURLVariables2/com.esri.ags.tasks:result() at mx.rpc::Responder/result() at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult() at mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders() at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent() at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler() at mx.rpc::Responder/result() at mx.rpc::AsyncRequest/acknowledge() at DirectHTTPMessageResponder/completeHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at flash.net::URLLoader/onComplete()
Error: Find criteria must contain at least one sort field value. at mx.collections::Sort/findItem() at mx.collections::ListCollectionView/getItemIndex() at oitt/pointMouseOver()
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
