I am receiving the following error message after I type in some addresses: faultCode:Channel.Security.Error faultString:'Security error accessing url' faultDetail:'Unable to load WSDL. If currently online, please verify the URI and/or format of the WSDL (http://www.geosmartniagara.ca/googleproxy/Service.asmx?WSDL)' I can access this URL from IE8 directly without a problem.
When you can access the URL directly but not from a flash application, it is usually due to either a missing crossdomain.xml file, or it's not configured to allow your flash application access.In this case, look at http://www.geosmartniagara.ca/crossdomain.xml and you'll notice that it only allows access for applications hosted on cogeco.ca. What's the URL for your application?<allow-access-from domain="*.cogeco.ca"/>
I've just posted a widget for leveraging Google's directions api. Download and enjoy, both compiled and uncompiled versions have been supplied. I've posted version 1 of the widget to get some comments and maybe see what additional functionality people may want. I have my own ideas but I'd like to get some feedback. Please remember to rate the widget if you like what you see.http://www.arcgis.com/home/item.html?id=20fc9fd1c43c45c5a1dbf8b4f03bee79
Thanks Mike Don't forget to rate it. I will have an update after I get a few more comments. I do have zoom to route working. I will be adding from and to points and tooltips along the route.
I'm trying run the widgets in 3.5 but i am running into an error on geometryService.project([p2 as Geometry], map.spatialReference);Implicit coercion of a value of type com.esri.ags:SpatialReference to an unrelated type com.esri.ags.tasks.supportClasses:ProjectParameters. GoogleRoutingWidget.mxml
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
