Same problem here, using Windows Server 2008 R2. Anyone have a workaround yet?
What part of the 'Mobile' folder structure did you change the authentication? (Admin, Content ect.) I've tried everything, including many hours with tech support, and we have yet to get the web server working with Mobile. I've tried alternate methods for creating mobile projects and they all seem to have issues, it's very frustrating.
Thanks for your reply. Have you tried uploading a Windows mobile project package via the 'Mobile Content Directory'? If you have, you have me beat. I get the following error: Access to the path 'C:\inetpub\wwwroot\ArcGIS\Mobile\ContentRoot\WindowsMobile\Traffic\8d0eb6cc51804deba573d2f1b7412a65' is denied. All of my security settings (Admin rights, UNC paths and Authentication) should be correct, yet I get this error? I haven't been able to fix this, and I have a real problem with continually tinkering around looking for a fix, while everything else works fine, including all our web services using Flex.
*Mobile working now*The Awesome Chris O. of ESRI support has helped resolve the last issues I had. These are the changes we made to get MPC and our Juno's working with the web server.IIS Authentication settings:Mobile (root) - Anonymous Auth enabledAdmin - Basic Auth enabled (only)Content - Anonymous Auth enabledContentRoot - Anonymous Auth enabledItemsRoot - Anonymous Auth enabled__________________________________Make sure that the Mobile root (via inetpub) has the "IUSR" added to the security tab, and that it has full control.Finally, don't forget that your webservice must be "Not Pooled" if you are doing any kind of edits. Otherwise you will get Protocol errors while managing your edits.-good luck
I am having this isuse as well. Oddly enough my settings already match all of the sugeestions in this post and actually I can post projects using my Trimble Yuma which runs a windows 7 OS. However I am getting the not being able to save behavior on my xplore tablets that are running win XP. Could this be an os issue. My web server is Win Server2008 R2. I am curious if any other are having issues using xp machines only. I am tempeted to reimage my xplore tabs with win 7 and see if that fixes the issue.
