#NAME: delta_road.py #AUTHOR: Kevin Bell #EMAIL: kevin.bell@slcgov.com #DATE: 20071207 # edited by Kim Ollivier #PURPOSE: create adds/deletes layer files by comparing 2 point # feature classes shape and attributes. If the shape has # not changed, but any of the attributes have, the feature # will show as a delete, and an add. #NOTE: buildDict method has hard coded primary key and attribute names. # mods : # use sets for del/add # write out featureclass differences # do not use centroid for lines, they have changed in a year! suggest length # do not use shape for non-points # dont forget to index keys for definition layers def buildDeltaLayers(inFC1, inFC2): '''build an adds and deletes lyr for a given chrono FC ''' print inFC1, inFC2 d1 = buildDict(inFC1) d2 = buildDict(inFC2) # find set differences and intersections to reduce dictionary comparisons startTime = time.clock() s1 = set(d1.keys()) s2 = set(d2.keys()) sNew = s2 - s1 print "New",len(sNew) sDel = s1 - s2 print "Del",len(sDel) sInt = s1.intersection(s2) print "Int",len(sInt) print "sets done" stopTime = time.clock() elapsedTime = stopTime - startTime print "elapsed time = " + str(round(elapsedTime, 1)) + " seconds" # could weed the dictionaries but will that be slower than just using the intersection set? compareList = valuesChanged(d1,d2,sInt) print "Changes",len(compareList) stopTime = time.clock() elapsedTime = stopTime - startTime print "elapsed time = " + str(round(elapsedTime, 1)) + " seconds" changes = len(compareList) if changes > 0 and changes < 50000: print "Changes to be written",changes makeLYR(inFC2, compareList, "rdchg") else : print "no changes, or too many to be believed",changes # must create delete layer first # to allow new features to be filtered for ID renumbering if len(sDel) > 0 : makeLYR(inFC1, sDel,"rddel") if len(sNew) > 0 : makeLYR(inFC2, sNew,"rdnew") def valuesChanged(dict1, dict2,sBoth): '''get a list of keys from one dict if a corresponding dict's values are different''' ## outList = [key for key in set(dict1.keys() + dict2.keys()) if dict1.get(key) != dict2.get(key)] outList = [key for key in sBoth if dict1.get(key) != dict2.get(key)] return outList def buildDict(inputFC): #-----BEWARE OF HARDCODED PRIMARY KEY AND ATTRIBUTES BELOW!!!!! '''Build a dictionary of the primary key, and its fields''' startTime = time.clock() d = {} cur = gp.SearchCursor(inputFC) row = cur.Next() while row: # only need to check primary keys and shape # oops row.shape.centroid always fails - why?? because its only an object reference # you have to get out the coordinates and put it in a real Python object d[row.GetValue(pk)] = [row.name.upper().strip() ]#, round(row.shape.length)] # d[row.GetValue(pk)] = [round(row.shape.length)] row = cur.Next() del cur print inputFC, stopTime = time.clock() elapsedTime = stopTime - startTime print "dict created, elapsed time = " + str(round(elapsedTime, 1)) + " seconds" return d def makeLYR(fc, inList, outLyrName): # BEWARE OF HARDCODED PRIMARY KEY BELOW '''Given a list, return a LYR file''' startTime = time.clock() wc = str(tuple(inList)) print outLyrName,len(inList) whereclause = pk+" IN " + wc # <----IF DATA ISN'T FILE GDB, YOU MAY NEED QUOTES/BRACKETS # print whereclause gp.MakeFeatureLayer_management (fc, outLyrName, whereclause) print outLyrName,"ORIG layer count",gp.GetCount(outLyrName).GetOutput(0) # remove changes of just RCL_ID if outLyrName == 'rdnew': print "RDDEL layer count",gp.GetCount("rddel").GetOutput(0) gp.SelectLayerByLocation_management(outLyrName, "WITHIN", "rddel","","REMOVE_FROM_SELECTION") print "Made NEW layer",outLyrName,round(time.clock() - startTime)," seconds" print outLyrName,"NEW layer count",gp.GetCount(outLyrName).GetOutput(0) gp.RefreshCatalog(delta_gdb) print outLyrName,"layer count",gp.GetCount(outLyrName).GetOutput(0) layerfn = os.path.dirname(delta_gdb)+"/"+outLyrName +".lyr" if gp.Exists(layerfn) : gp.Delete(layerfn) ##gp.SaveToLayerFile_management(outLyrName, layerfn) # print "saved layer",round(time.clock() - startTime) deltaFC = delta_gdb+"/"+outLyrName # Warning, featureclass MUST be indexed on PK! if not gp.Exists(fc) : print fc,"not found" ## gp.AddIndex_management(fc,pk,fc+"_"+pk+"_idx") if gp.Exists(deltaFC): gp.Delete(deltaFC) gp.CopyFeatures_management(outLyrName,deltaFC) stopTime = time.clock() elapsedTime = stopTime - startTime print outLyrName,"elapsed time = " + str(round(elapsedTime, 1)) + " seconds" #---------------------------------------------------------------------- print "----------- delta road ----------------" import arcgisscripting, time,os,sys gp = arcgisscripting.create(9.3) gp.overwriteoutput = True try : last_gdb = sys.argv[1] current_gdb = sys.argv[2] delta_gdb = sys.argv[3] except : last_gdb = "E:/road_jan2009.gdb" current_gdb = "e:/crs/mobile/mobile.gdb" delta_gdb = "E:/crs/road_roadname.gdb" if not os.path.exists(delta_gdb) : gp.CreateFileGDB_management(os.path.dirname(delta_gdb), os.path.basename(delta_gdb)) gp.Workspace = delta_gdb gp.OverwriteOutput = 1 print for laydef in [["road","RCL_ID"]] : layer = laydef[0] pk = laydef[1] startTime = time.clock() print "Start" old = last_gdb+"/"+layer new = current_gdb+"/"+layer ready = True if not gp.Exists(old) : print old,'not found' ready = False if not gp.Exists(new) : print new,'not found' ready = False if ready : buildDeltaLayers(old,new) msg = "Your del/change/add fc's are in:" gp.AddMessage(msg) print str(gp.workspace) gp.AddMessage(str(gp.workspace)) stopTime = time.clock() elapsedTime = stopTime - startTime print layer,"total elapsed time = " + str(round(elapsedTime, 1)) + " seconds" else : print "not ready" # del gp print "-------------------------------------------------------------" gp.AddMessage("finished")
Did you ever find a solution to ObjectID being the default unique ID for a feature compare? I'm using ArcGIS 10.2.2 and it still does this.
Hi Alan,
I'm working on something similar using the Feature Compare tool. I'm having the same problem were the tool is using the ObjectID as the unique identifier. Did you ever find a solution to select your preferred unique identifier?
Manuel
The Feature Compare tool has clearly been designed to solve a very narrow problem and is not suitable for many change detection problems. There is no chance that the tool will be changed to widen the scope because it will break backward compatibility. It is very hard to write a generalised tool -try it!
The simple solution it to write your own. It will be faster and better because Python has excellent structures to do this. I posted my own customised change tool using a user-id as an example below that shows how to use a dictionary to handle a custom primary user key that does not need to be indexed in the source table. This is because a dictionary has it's own hash key that is very efficient and fast.
Hi Kim
You wrote..."I posted my own customised change tool using a user-id as an example below that shows how to use a dictionary to handle a custom primary user key that does not need to be indexed in the source table"
I do not see this example - could you post it again? Much appreciated.
Re: Compare Feature and attribute
I thought everyone can see all the replies to this thread. Is this why people have been asking the same question?
Cheers Kim - now all is clear. Thank you. Perhaps it was too many late nights migrating SDE to 10.2.2. I just needed fresh pair of eyes.
Data Interoperability extension can compare two arbitrary data sources without any shared key requirement and drop out unchanged/insert/delete or CRUD sets insert/update/delete over any set of geometry or attribute comparisons. If the scripted approach doesn't work for you email me at bharold@esri.com with sample data and I'll run it.
