TypeError arguments: Array[2] get message: function () { [native code] } get stack: function () { [native code] } set message: function () { [native code] } set stack: function () { [native code] } type: "non_object_property_load" __proto__: Error arguments: undefined constructor: function TypeError() { [native code] } arguments: null caller: null length: 1 name: "TypeError" prototype: Error __proto__: function Empty() {} name: "TypeError" stack: undefined type: undefined __proto__: SetUpError.d constructor: function Error() { [native code] } message: "" name: "Error" toString: function toString() { [native code] } __proto__: Object dojo.js:15 dojo.Deferred.reject.errback dojo.js:15
Adam,I looked at your SD. It looks like you are using Level of Details = 20. That means you are generating a cache of 270 GB. You can verify that by clicking on "Calculate Cache Size" button on Service Editor dialog box in ArcMap and then estimating cache by clicking on "Start" button. Please observe that even though you are trying to publish a data around 20 MB your cache size is around 270 GB for Level of Details = 20. This is because higher number of Level of Detail require more number of tiles to be generated, which requires more storage space.I am not sure how much space your organization has but, it looks like this is the bottleneck in your case. I would suggest reducing Level of Detail = 2 (may be 5), then see how much space it requires and publish it accordingly.
Adam,You are looking at Service definition. You should look at "Map Service" in your org. You will see Manage Tiles link.
Yes, I'm using 10.1.My service is here:https://lcbp.maps.arcgis.com/home/item.html?id=c22ea5ea0a6d461c97698e590031bc6fThanks,Ryan
I'm also on 10.1. You can view my SD here:http://www.arcgis.com/home/search.html?q=amebc&t=contentDo I need to add you to the members list so that you can see the SD? If so, do I need your e-mail?
Hmmmm, I don't seem to have the Manage Tiles link. I just recreated the SD file with the build cache manually option selected and it look pretty much the same as all my other attempts:[ATTACH=CONFIG]15466[/ATTACH]
