When I was testing Collector I made a test feature but got a message that the update failed-updates could not be sent and I can cancel or retry. Cancel abandons the feature and retry returns the same result.
Are you using hosted or your on-premise server?
Are you able to collect in AGOL?
If you try in AGOL - collect a feature and refresh your browser page and see if the feature still exists or see if it made it back into your SDE. This will help us determine where the issue is.
Thanks
Russ
I am using an on-premise server.
It doesn't appear I am able to add features in AGOL either. It says click to add a point and then nothing happens. I have several feature layers present in this particular map and none of them appear to work, actually one works for some reason but the rest don't. I have done some schema changes, would that cause the issue? If so, how can I fix this issue?
I don't think that would cause the issue. If you can enable debug logging on your server or look at the network requests when you try to add you might be able to determine the issue.
The log repeatedly says a database error has occurred after I attempt to add a feature, nothing more. The source is featureservice.mapserver. The service featureservice appears to be running. Yes I know simple name but the idea was this was a test service. Fiddler doesn't return anything on a click. Also interesting is that I apparently can edit existing points in AGOL. However, even edits will not post from Collector. Again, I am able to edit one of my features without issue in Collector and in AGOL.
Just an update, we are still testing out and haven't officially taken the plunge yet (yep a year later) but to the best of my knowledge this error is no longer happening and to be completely honest, I have no idea what we did to fix it anymore or if a bug fix was patched on. I have always been in online mode, so archiving wasn't my issue and I never saw the error mentioned above.
