Dear Gurus!
How to calculate the coordinates of the distance from the beginning of the road on a layer of the line features?
You should make the nodes of the line of that've road , each node have coordinate. You can use a tool ET GeoWizards, ET GeoTools and ET Surface for ArcGIS - Downloads
IT works with argis software and it free. In the geowizard you should convert line to points and then you will get the nodes with coordinates.
Sorry, how to this with WPF API?
Anatoli, it might be easier if you post your questions in this place assuming that this is the correct one
What I must to do to post question on the another thread ?
You can look at this Silverlight Sample that demonstrates how to calculate at client side the shortest distance between a point a set of lines or polygons.
Another option is to calculate at server side using the Geoprocessing tools.
The shortest distance is not the case. Geoprocessing tools I will see. I'm looking at the moment the decision in WPF, not in Silverlight. And while I do not understand what means "to do on the server", and how it is associated with the MAP service. I will try to do this using arcobjects. Thank you.
P.S. Sorry. I understood everything. In my case server and client side are on one computer.
