Hi Robert
I have tried to install Flash Builder 4.7. on windows 8.1 and im not able to debug the application. I have tried many different version of flash player but no use. Sorry to ask 2 question in a row but im kinda stuck in this from last one month . I have been developing my app on a temp system of windows xp . debugger works fine with it but it shows error "source not found" when ever i try to debug a line which refer a class of arcgis api
Please help me in this
regards
Saurabh,
That is not an error, it is an information message that you are going to get past. The ArcGIS Flex API is NOT open source as the whole adobe flex API is and thus you will not have access to the source code of the ArcGIS Flex API.
Hello Robert
Thanks for the reply . So we can only know the output of flex API and can set debugger at those point only not on Arcgis API?. I would be highly thankful if you can through some light on my second problem as
How to Debug flexviewer 3.6 application on Windows 8.1 using flash builder 4.7
Thanks in Advance
Saurabh
You can place break points and debug an application built using the ArcGIS Flex API. But you will not be able to see the source of individual ArcGIS Flex API components like you can say for the Adobe Flex DataGrid. I do not do any development using a Windows 8.1 machine. My Development laptop is Windows 7. So what kind of problem are you having with debugging on Windows 8.1? Just saying that it does not work is not going to allow me to help you.
Robert
Ok. About 8.1 problem when I am importing flexviewer 3.6 app into flash builder 4.7 is says that this project is build in earlier version and do i want to change it to new version and what SDK i want to use for the same. After doing all this when i am running the application . it runs fine but when im trying to debug it is shows error of flash player version and ask me to either download a flash player version or re install Flash Builder. I have shown the error below,
I have tried to install new version of windows debugger and changed in option to set to its version of flash player but still same result.
Please guide me on this issue as i cant use windows xp any more and my development is kinda at hault.
Thanks in advance
Can you try to set your default web browser to Firefox and then try again?
I have done that also and the error just changed a bit instead of chrome error it showed me firefox one
Regards
