Hi Robert
I have tried to install Flash Builder 4.7. on windows 8.1 and im not able to debug the application. I have tried many different version of flash player but no use. Sorry to ask 2 question in a row but im kinda stuck in this from last one month . I have been developing my app on a temp system of windows xp . debugger works fine with it but it shows error "source not found" when ever i try to debug a line which refer a class of arcgis api
Please help me in this
regards
Saurabh,
That is not an error, it is an information message that you are going to get past. The ArcGIS Flex API is NOT open source as the whole adobe flex API is and thus you will not have access to the source code of the ArcGIS Flex API.
Hello Robert
Thanks for the reply . So we can only know the output of flex API and can set debugger at those point only not on Arcgis API?. I would be highly thankful if you can through some light on my second problem as
How to Debug flexviewer 3.6 application on Windows 8.1 using flash builder 4.7
Thanks in Advance
Saurabh
