''' ParsingDataDemo.py A demo file to parse data which is quasi-fixed width File and script must reside in the same folder...fix this if you want ''' import sys, os data_path = (os.path.dirname(sys.argv[0]) + "/").replace("\\","/") #can be skipped if you follow data_file = data_path + "ParsingDataDemoData.txt" #fix this or better still create a tool #data_file should be sys.argv[1] which allows a user to select a file in a folder a_file = open(data_file) data = a_file.readlines() for a_line in data: record_type = a_line[:3] parcel_num = a_line[3:11] the_rest = a_line[11:] print record_type, parcel_num, the_rest
'120' # record type - the 'key' L ['12345678AFIXEDWIDTH', '12345678FIXEDWIDTH'] # other info, stored within a list '110' L etc., etc.
# Read mode opens a file for reading only. DataFileIn = open("input.txt", "r") # Read all the lines into a list. DataList = DataFileIn.readlines() DataFileIn.close() DataDict = {} for item in DataList: # iterate over the rows - each item is the string of data RECORDTYPE = item[0:3] # get parts 0 to 3 of the string (first 3 digits) item_ = item.strip('\n') # get rid of new line characters at the ends (if they are there - does nothing if not) try: DataDict[RECORDTYPE].append(item_[3:]) # try to append the rest to the dictionary sub-list as a list item except KeyError: DataDict[RECORDTYPE] = [item_[3:]] # if this is the first time this record has appeared, add it as a list item for key in DataDict: # for every record type DataTextOut = open('output_%s.txt' % key, 'w') # i.e. output_120.txt for item in DataDict[key]: # for each line in the list DataTextOut.write(item+'\n') # write the data, then add a new line DataTextOut.close() # close this particular file
#test.txt= #10012345678ABCDEF123abc #11012345678ABC12345abcd #12012345678111111abcdef #10012345678AABCDEF123abc #11012345678AABC12345abcd #12012345678A111111abcdef testtxt = open('D:/Python_Tests/test.txt', 'r') testlist = testtxt.readlines() testtxt.close() dict_ = {} for item in testlist: RECORDTYPE = item[0:3] item_ = item.strip('\n') try: dict_[RECORDTYPE].append(item_[3:]) except KeyError: dict_[RECORDTYPE] = [item_[3:]] for key in dict_: textout = open('D:/Python_Tests/textout_%s.txt' %key, 'w') for item in dict_[key]: if key == '100': textout.write('100'+','+item[:9]+','+item[9:18]+','+item[18:21]+','+item[21:23]+'\n')#I added the if and elif to format each record type separately elif key == '110': textout.write('110'+','+item[:9]+','+item[9:12]+','+item[12:18]+'\n') elif key == '120': textout.write('120'+','+item[:9]+','+item[9:12]+','+item[12:]+'\n') textout.close()
for key in dict_: textout = open('D:/Python_Tests/textout_%s.txt' %key, 'w') for item in dict_[key]: if key == '100': textout.write('100'+','+item.ljust(5)+'n'+'\n') elif key == '110': textout.write('100'+','+item[:9]+','+item[9:18]+','+item[18:21]+','+item[21:23]+'\n') elif key == '120': textout.write('100'+','+item[:9]+','+item[9:18]+','+item[18:21]+','+item[21:23]+'\n') textout.close()
12012345678ASOMEOTHERSTUFF
file: 120 # parcelnum, text 12345678A,SOMEOTHERSTUFF
file: 120 # parcelnum, text 1234567,8ASOMEOTHERSTUFF
testtxt = open('D:/Python_Tests/test.txt', 'r') testlist = testtxt.readlines() testtxt.close() dict_ = {} for item in testlist: RECORDTYPE = item[0:3] item_ = item.strip('\n')) try: dict_[RECORDTYPE].append(item_[3:]) except KeyError: dict_[RECORDTYPE] = [item_[3:]] for key in dict_: textout = open('D:/Python_Tests/textout_%s.txt' %key, 'w') for item in dict_[key]: if key == '100': textout.write('100'+','+item[:9]+','+item[9:10]+','+item[10:14]+','+item[14:18]+'\n') elif key == '110': textout.write('110'+','+item[:9]+','+item[9:18]+','+item[18:35]+'\n') elif key == '120': textout.write('120'+','+item[:9]+','+item[13:613]+','+'\n') textout.close()
testtxt = open('D:/Python_Tests/test.txt', 'r') testlist = testtxt.readlines() testtxt.close() dict_ = {} def chomp(s): return s[:-1] if s.endswith('\n') else s #Keeps trailing whitespace for item in testlist: RECORDTYPE = item[0:3] item_ = chomp(item) #used in place of xyz.strip('\n') try: dict_[RECORDTYPE].append(item_[3:]) except KeyError: dict_[RECORDTYPE] = [item_[3:]] for key in dict_: textout = open('D:/Python_Tests/textout_%s.txt' %key, 'w') for item in dict_[key]: if key == '100': textout.write('100'+','+item[:9]+','+item[9:15]+','+item[15:18]+','+item[18:]+'\n') elif key == '110': textout.write('110'+','+item[:9]+','+item[9:12]+','+item[12:17]+','+item[17:]+'\n') elif key == '120': textout.write('120'+','+item[:9]+','+item[9:15]+','+item[15:]+'\n') textout.close()
>>> "a\n".rstrip() 'a'
get first three digits get next nine digits if first three digits == '120' get next four digits # and so on...
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
