XMLHttpRequest cannot load http://ARGISserver/arcgis/rest/services/LIVEinternal/aerials/MapServer/legend?f=json. The 'Access-Control-Allow-Origin' whitelists only 'http://appURL'. Origin 'http://appURL_dev' is not in the list, and is therefore not allowed access. (index):1 k {stack: "Error: Unable to load http://ARGISserver/arcgis/rest???ev/arcgis_js_api/library/3.7/3.7/init.js:3570:29)", message: "Unable to load http://ARGISserver/arcgis/rest/servic???nternal/aerials/MapServer/legend?f=json status: 0", response: Object, status: 0, responseText: ""???}
<system.webServer> <httpProtocol> <customHeaders> <add name="Access-Control-Allow-Origin" value="*" /> </customHeaders> </httpProtocol> </system.webServer>
XMLHttpRequest cannot load http://my server name/arcgis/rest/info?f=json. The 'Access-Control-Allow-Origin' whitelists only 'http://myURL, *'. Origin 'http://myURL' is not in the list, and is therefore not allowed access.
bump - still getting this - anyone any ideas how to make it stop?
Adrian,
Have you considered just turning cors detection off? esri.config.defaults.io.corsDetection = false;
Not sure I know where to put that. However, I replaced the * in the
http://server/arcgis/admin/system/handlers/rest/servicesdirectory
With some random text and that sorted it. I think too many things were trying to do the same thing - I have really no idea what I am talking about.
Brill - that worked as well - much better than playing with options I had no idea about, many thanks
Using Server Manager, in IIS, you can navigate to the site and under the HTTP Response Headers you can choose ADD, then title Access-Control-Allow-Origin and value is the IP or domain of the site you want to allow. Could always choose * for everyone.
While you can do it in your code, Server side is probably the best option.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
