Does anyone know if there is a way to identify or select polygons that touch one another? I have looked at the topolgy rules, and the rule for overlapping polygons doesn't work, the polygons just share a boundary rather than overlapping. Ideally I would like to be able to do this without having to convert to polygons to lines, so if there is a clever way this can be done, please let me know!In the attached jpg you can see the two polygons that touch are selected, but this was done manually. Is there an automated method of doing this?
You can run the Near tool using the same features as the Input Features and Near Features. It adds a field NEAR_DIST, storing distances to the nearest features.Run Select Layer By Attribute to select polygons with the NEAR_DIST = 0. Does that give you what you want?
this works a treat! I wasn't aware of the Near tool before, so that is really useful to know.
