Server Error in '/Builder' Application.--------------------------------------------------------------------------------Failed to access IIS metabase. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Web.Hosting.HostingEnvironmentException: Failed to access IIS metabase. The process account used to run ASP.NET must have read access to the IIS metabase (e.g. IIS://servername/W3SVC). For information on modifying metabase permissions, please see http://support.microsoft.com/?kbid=267904.Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
My website is not running. Nothing displays in the browser (when navigated to http://<computer name>/Builder/default.aspx) except for the error message that I posted at the beginning of the thread. I am unfamiliar with setting the permissions on the files you mentioned above, would it be possible for you to further explain how to go about doing this?Thanks!
Hi Matt,What OS are you running?Are you sure your machine meets all the system requirements?Did the Silverlight Viewer install without issues?FYI, ArcGIS Viewer for Silverlight system requirements.Hope this helps,
Is you Web site running? Does the Builder web application show as started and listed in IIS? Does any part of the Builder web application display? Does the page display if you type url http://<computer name>/Builder/default.aspx in your browser? Is there any more details you can provide?Try setting the permission on the Builder web application.C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -iC:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -ga <Computer Name>\ASPNET
