It appears that the functionality for adding links (under the Attributes tab) is not working. I enter a URL and every link opens a new browser tab opening to a blank page. Any help??
Thanks !
Tim,
When you click "Add New Link" the first thing that you are specifying is the text that will appear in the link, next you double click on the "Double click to edit link URL" and this is where you enter the URL. Hope this helps.
That was too easy! Thanks!!
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
I'm totally piggy backing off this thread but wanted to ask a related question...
It's easy to add links and easy to add them in the WAB Developer edition. But, can you change the font style of these links? Particularly just putting in an underline (or changing the color)?
"links":[ { "url": "http://www.arcgis.com", "label": "ArcGIS Online" } ],
This is in the config.json file.
Adrian,
sure just add this css rule to your chosen themes common.css file:
.jimu-link:link, .jimu-link:visited {
text-decoration: underline;
Robert,
You're the best. I'll try this out tomorrow. Thanks!
Edit: Worked like a charm! Thanks again Robert.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
