The conflict between netCDF4 and ArcGIS has a long and illustrious history. Example here.Your problem sounds different from the one I had a few years ago, though. So small chance it's a problem with your code. Beyond that, there are at least two alternative netCDF readers that do work with ArcGIS:ScientificPython - I've been submitting Windows installers for this project. Right now the latest one is compatible with AGD 10.0.scipy.io.netcdf - This will bomb on really, really big files. ScientificPython won't.There are others, and they all use very similar APIs. Unfortunately, none of them offer the cool bells-and-whistles that netCDF4 offers.Hope that helps.
Hey, thank you for the response. I am running AGD 10.1, which uses python 2.7. It looks like the latest windows installer is for python 2.6. I believe I tried this one and was having compatibility issues with ArcGIS 10.1. Do you know any window installers for python 2.7? Thanks again.
Just a week ago Christoph Gohlke built a completely static NetCDF4 module specifically for use with ArcGIS 10.1, and in my testing it has worked flawlessly. Check out the link to netCDF4-1.0.5dev-ArcGIS-10.1.win32-py2.7.exe on Christoph's amazing Python libraries for Windows page: http://www.lfd.uci.edu/~gohlke/pythonlibs/#netcdf4
Thank you so much for the responses. I downloaded the python 2.7 version of ScientificPython, and for some reason I am not having success running the module within Arc. I keep getting an error of "IOError: netcdf: Invalid argument", but the same argument seems to be working outside of Arc. I also downloaded the mentioned netCDF4 module and I am getting the same error I was originally getting in the first post. My script runs perfect one time through, but then the next time through I am have problems. I first read in the netcdf file using:dataset= Dataset('nameofmynetcdf.nc')And then I try and read the latitudes using the command: lt = dataset.variables['lat'][:]This works perfectly the first time through, but then second time through I get an error for this line which states:AttributeError: 'NoneType' object has no attribute 'iterable'Does anyone know why this would be? I am reading this data via opendap if that makes any difference at all(?). I would really appreciate any help anyone has to offer. Thank you!
I also downloaded the mentioned netCDF4 module and I am getting the same error I was originally getting in the first post. I am reading this data via opendap if that makes any difference at all(?). I would really appreciate any help anyone has to offer. Thank you!
from netCDF4 import Dataset data= 'http://cloud.insideidaho.org:8001/reacch/CMIP5/maca_huss_BNU-ESM_historical_1950_1959_WUSA.nc' MyData=Dataset(data) lt = MyData.variables['lat'][:] arcpy.AddMessage(lt)
Here is a condensed version of my code. You probably won't be able to access this data, but if you know of any other opendap data with a latitude variable, you could substitute that in the data line. from netCDF4 import Dataset data= 'http://cloud.insideidaho.org:8001/reacch/CMIP5/maca_huss_BNU-ESM_historical_1950_1959_WUSA.nc' MyData=Dataset(data) lt = MyData.variables['lat'][:] arcpy.AddMessage(lt) When I run as a script in an ArcGIS toolbox, it runs successfully the first time, and prints off all of the latitudes, the second time however, I get this error message:Traceback (most recent call last): File "C:\netcdf4 trouble\netcdf4problem.py", line 5, in <module> lt = MyData.variables['lat'][:] File "netCDF4.pyx", line 2631, in netCDF4.Variable.__getitem__ (netCDF4.c:32455) File "C:\Python27\ArcGIS10.1\lib\site-packages\netCDF4_utils.py", line 127, in _StartCountStride if np.iterable(elem):AttributeError: 'NoneType' object has no attribute 'iterable'Failed to execute (netcdf4problem).
Nothing is jumping out at me. I can see that the climate variable has 3,650 time steps. Is your script designed to repeat itself 3,650 times in order to extract the climate variable and lat/lons for each time step?
Something isn't making sense. The line that is throwing the error is doing nothing except checking to see if "elem" is an iterable. If you open up this file: "C:\Python27\ArcGIS10.1\lib\site-packages\netCDF4_utils.py", it looks like the import of numpy as np (on line 1) is only being executed successfully the first time you run the tool. Subsequent runs fail and only return a NoneType object. I have no idea why.Hopefully someone else can enlighten us both.
Yes, very frustrating! I appreciate you taking a look though. So does the ScientificPython module not read opendap? I was thinking that may be a decent alternative if this issue can't be worked out, but I get an invalid argument error when I try and put in a url for the netcdf dataset.
from pydap.client import open_url daymetfile = open_url(r'http://daymet.ornl.gov/thredds/dodsC/allcf/2011/12484_2011/tmax.nc') var_raw = daymetfile['tmax'].array[100,:,:] # this slices out data for the 100th day # then I had to do some reshaping of the array and convert it to a raster using arcpy # maybe there is a better way to do this?
I think netCDF4 is the only package with built-in OPeNDAP support. I've used Pydap, but there are no Windows installers that I know of. You can install it using pip or easy_install. And it isn't as clean as the netCDF4 syntax:from pydap.client import open_url daymetfile = open_url(r'http://daymet.ornl.gov/thredds/dodsC/allcf/2011/12484_2011/tmax.nc') var_raw = daymetfile['tmax'].array[100,:,:] # this slices out data for the 100th day # then I had to do some reshaping of the array and convert it to a raster using arcpy # maybe there is a better way to do this? I would say that netCDF4 is the preferred alternative. The error you're getting doesn't make much sense.Are you running the condensed code you posted earlier out of a Custom Toolbox or Python Toolbox?
pydap is what I have been using, but recently I have been trying to access data on a thredds server rather than an opendap server, and pydap was giving me issues on the thredds server that I never experienced with the opendap server, so that is when I decided to try netcdf4. The netcdf4 module worked on the thredds server, but only once, like I have explained, and then I keep getting this error each subsequent run. This code is being run out of a normal toolbox. I have never used a python toolbox, do you think that could be the problem?
Hi All,
I am running into the same issue, using ArcGIS 10.2.2 and the netCDF4 module.
I can confirm that this has nothing to do with the script, which runs fine outside or Arcgis. It also runs fine the first time, before crashing invariably:
File "netCDF4.pyx", line 2986, in netCDF4.Variable.__getitem__ (netCDF4.c:36632)
File "C:\Python27\ArcGIS10.2\ArcGIS10.2\lib\site-packages\netCDF4_utils.py", line 137, in _StartCountStride
Would a completely statically linked version of netCDF4 fix this problem on 10.2.2 as well?
FYI, for whoever might run into a similar issue, I manage to partially resolve the issue by not running the script "in process". I also had to isolate the netcdf part of the code in its own script, (run outside the main process).
this is very messy because it basically opens a command prompt and starts the script like this:
path_to_script.py "arg1" "arg2" "arg3" .... If users have conflicting python instances, or if py files are not associated with the correct interpreter (for example if associated with a text aditor as many people do) it will fail.
Any help or idea appreciated...
We have exactly the same issue, a script from a custom toolbox can be executed only once and then it results in an "AttributeError: 'NoneType' object has no attribute 'iterable'" when trying to subset a variable like:
ArcGIS 10.1 SP1 on Win 7 with netCDF4 1.0.4 installed along with the ArcGIS Multidimensional Toolbox.
Any help would be much appreciated!
Filip.
I think the best solution to this issue is to use the scientific python package available with ArcGIS Pro and soon to be available for ArcGIS 10.4.
Strengthening the Link between GIS and Science | Esri Insider
Esri and the Scientific Community 2015 Roadmap
I am using ArcGIS for Server 10.4 and am getting the same error when running the geoprocessing service more than once.
Fix: If you use a Python Toolbox versus a Script tool, the problem goes away. Hope this helps.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
