Thank you very much, this proved to be of great help to us.I have one question though, I customized the application to fit out need. Here is the link to it.http://cityview.baltimorecity.gov/maps/Everything looks alright on all browsers but on IE. On IE the legend tab turns out blue. I checked out the css and looks alright esp. when I have no issues with other browsers. Can you please tell me what needs to be done to display it right on IE.Thanks a lot.
We would like to use arcgis explorer online instead of the simple viewer. Is this possible and if so how do I configure this?
The public map gallery template is very nice - several departments at the City of Albuquerque are highly interested in using it to share maps with the public. However, there is a need to allow users to turn on and off layers. This can be done now - sort of. You have to click on About, then Map Contents, then Open, then Open in ArcGIS.com Viewer, then click an unlabeled button. Hard for the average citizen.It would be much more useful and simple to just enable turning on and off layers in the Legend section of the map in the gallery. Thanks,Mike RockGIS AnalystCity of Albuquerque
Hello,I would like to remove the footer and the yourLogo image. Does anyone know what file needs to be edited?Thanks,JP
Yes, this is possible and will be a config option in the next release.Currently, you'll have to go into "/scripts/home/local.js" and search for "map.html" and change that to "http://www.arcgis.com/home/webmap/viewer.html".Thanks
This sends it to the arcgis.com viewer, can you send it directly to Explorer Online? Also how do you change the url for your logo so that it goes to our homepage? Sorry but I am not a developer either.
map.html?webmap=
http://explorer.arcgis.com/?open=
<div class="logoDiv footBorder"><a title="Your Logo" href="http://yourwebsite.com" class="hostedBy"></a><a href="mailto:email@yourorg">email@yourorg</a></div>
Yep. You should be able to change it to use ArcGIS explorer. Instead of using the previous URL, use this one. Instead ofmap.html?webmap=Usehttp://explorer.arcgis.com/?open=If you open index.html or map.html and scroll to the bottom. you can change the code below to use your website link. The HREF attribute of the <a> anchor tag.<div class="logoDiv footBorder"><a title="Your Logo" href="http://yourwebsite.com" class="hostedBy"></a><a href="mailto:email@yourorg">email@yourorg</a></div>Hope that helps. Let me know if you get it working.
Sweet, it works great thanks. I wasn't putting http:// in front, but it works now.
The initial map will not load in the carosel view. The wheel just keeps spinning....
I can't seem to figure out how to resize the footer elements. I need to bring our logo and that little border line more to the left and closer the the "About..." description.
I have two questions regarding the functionality of users viewing the template. Is there an option to make the full screen view available in the Carousel View or is this only possible in the simple map viewer through map.htm? Also, I am having trouble with layer descriptions appearing in the legend tab of map.htm. These layer descriptions display in the Carousel view, but not in the simple map viewer when a user clicks on a map from index.htm. (With the addition of descriptions appearing in the legend of map.htm will these changes be affected in the full screen view? Also, will users be able to toggle layers on/off in the full screen view? I followed code in response to cstevens5802's post.)Also, running into errors displaying web maps that use Bing Maps base layers. I registered for a Bing Maps key and inserted this into the config.js file. Is there more to editing the config.js file than simply copy/pasting Bing Maps key between the quotes?Designing the template to display/grade student's university lab assignments. I am encouraging the students to design purpose driven web maps with quality appeal to client-side viewing. Thanks for any help you are able to provide. URL is maps.UNOGIS
Unfortunately, the carousel view doesn't have a fullscreen. Only the simple viewer does.I'll look into why those layers aren't displaying for you. Thanks for pointing that out. I'll hopefully have a fix for that soon.Yes, pasting the Bing Maps key in the config is all you need to do to use Bing Maps. Is it not working for you?
You should be able to change these by changing the grid_6 and grid_3 classes in the HTML file to adjust the size. You can get rid of the empty grid_3 and that gives you some more room to play with. Try making the grid_3 into a grid_4 and see if that helps. I'ts using the 960.gs grid system.
OK cool, thanks. Also, how do you configure Explorer Online to open in a new window when you click on the thumbnails so the original tab (index.html) stays open?
html += '<li class="item ' + itemClass + '"><a target="_blank" title="' + data.results.snippet + '" href="' + itemURL + '"><img src="' + obj.arcgispath + obj.imagepath + data.results.id + obj.imagepath2 + data.results.thumbnail + '" width="200" height="133"><span>' + itemTitle + '</span></a></li>';
<a target="_blank"
If you look in "/scripts/home/local.js" on line 101 you should see where it builds the thumbnail. If you change the anchor tag to have target="_blank" like so, it should do that for you.html += '<li class="item ' + itemClass + '"><a target="_blank" title="' + data.results.snippet + '" href="' + itemURL + '"><img src="' + obj.arcgispath + obj.imagepath + data.results.id + obj.imagepath2 + data.results.thumbnail + '" width="200" height="133"><span>' + itemTitle + '</span></a></li>';<a target="_blank"
#legendMenu .esriLegendServiceLabel { display:none; }
Is anyone having trouble viewing the map gallery in IE 9? I've been playing with it on our internal network so I don't have a URL to share, unfortunately. I have been working with it in Firefox and Chrome without issue but decided to check in IE. The map will not load - the circle just spins and spins.Thanks.PS: Apparently, I can't see any of my maps at all on Arcgis.com with the viewer in IE 9 but I CAN see ESRI sample maps there. Strange. Thoughts?
That's odd. Do you think you could email me the URL or the web map ID that is having a problem? Maybe I can help out.Esri_webmap@esri.comThanks
Is there a way to increase the amount of content that shows up on the Carousel View? Currently, it is showing only the 10 most recent maps. Thanks.
I've downloaded the code, looked up my group, and replaced the group number in the config.js file, but it still doesn't show my maps. Am I doing something wrong?
