Hello guys,
Assistance please,
I have a table below;
From there i created a new field "code" so i want to calculate a sequential numbers based on how much the "Unique_no" appears like the one below;
Regards,
Kelvin.
You could do this with an update cursor and a dictionary, something like this...
data_dict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fcName<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Unique_no"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Code"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> Cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> Cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">in</SPAN> data_dict<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># increment counter</SPAN> data_dict<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> data_dict<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="comment token"># update code</SPAN> cnt <SPAN class="operator token">=</SPAN> dat_dict<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> cnt Cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks Neil,
See if I'm wrong somewhere because i am not good in python.
Firstly try and run this as a script in IDLE or pyscripter or something.
You have the indentation wrong. The line starting else:
Should be at the same level as the if:
Indentation in python is a crucial part of the language syntax.
Try doing a bit of reading up on python first.
And the last 3 lines also at the same indentation level as the if:
Using defaultdict allows the code to be simplified/condense a bit:
<SPAN class="keyword token">from</SPAN> collections <SPAN class="keyword token">import</SPAN> defaultdict data_dict <SPAN class="operator token">=</SPAN> defaultdict<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fcName<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Unique_no"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Code"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> uniq<SPAN class="punctuation token">,</SPAN> code <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> data_dict<SPAN class="punctuation token">[</SPAN>uniq<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN> cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>uniq<SPAN class="punctuation token">,</SPAN> data_dict<SPAN class="punctuation token">[</SPAN>uniq<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
