Since the Last release off Arcgis Online (20160914) we have been unable to create a replica from a Feature -layer. We can not create shapefiles - but we can create FileGeodatabase.
Doesn´t AGOL support the creation of replicas in the format of .shp any longer or is it a bug that you plan to fix?
Look at the attach image! It worked yesterday.
Hello,
I'm not sure if you have been contacted by support yet, but I have an update on the particular issue. The development team has identified this as a bug and will address the issue tomorrow night (Pacific Time).
-Kelly
Please contact technical support to look into this issue further. Let me know if you need any help getting in touch with support.
Thank you,
Kelly
It would be nice to get in contact with the technical support. Please give me a hand.
It works! Thanks for a fast response - we didn´t needed to do expensive workarounds.
We are seeing issues with create replica in shape format. We are trying to get features within a polygon as shapefile. It does not work when a polygon geometry is supplied while creating the replica. It returns a zip file containing the shapefile, but the shapefile always has zero features. We have confirmed that the polygon contains features from the layer, but it always returns 0 features in the zipfile.
It works well when filegdb is set as the output format and we are able to see only features within the polygon.
If we do not provide the polygon geometry, then it works and downloads the complete dataset as shapefile. But we are looking for downloading only within specified polygon geometries.
Hi Anand,
I recommend contacting technical support to look into this issue further. Are you specifically trying to extract the data?
This tool is available with the output of a shapefile. You can also clip the features returned to a specific polygon:
Extract Data—ArcGIS Online Help | ArcGIS
