Hi, ESRI is aware of this upgrade issue and a software bug has been logged: "NIM084987-When upgrading an ArcGIS 10 SP5 geodatabase to ArcGIS 10.1, while connecting with the syntax 'sde: oracle11g:TNSNAME' the upgrade fails with the error 'ERROR: geodatabase schema object install not completed (-522)."http://support.esri.com/en/bugs/nimbus/TklNMDg0OTg3-The workaround for this bug is to use the easy connect syntax to connect to the geodatabase or if you have the TNSNAME entry setup for the Oracle client, just make a connection to the Oracle geodatabase by typing only the TNSNAME in the 'Instance' textbox.
Hy,
I just got it fixed by inluding the database @<instance name> in the password field:
Like this:
DataBase instance: GIS
Username: sde
Password: sde@GIS
Running under 10.3 with oracle on Linux
Tom
Thank you Tom! This solved it for me. I actually was upgrading from 10.0 sde to 10.22 sde.
I was able to get the Upgrade Geodatabase tool to work by creating a new database connection using only the Oracle TNS name in the Instance text box, click OK, name the db connection and exit ArcCatalog. Once I re-open ArcCatalog/ArcToolbox and attempt to upgrade, it runs successfully. (SDE 10.2.1 to 10.3.1)
