<value prompt="Example: 181001490000 ">APN LIKE %[value]%</value>
ADDRESS LIKE '%[value]%'
Jay, The only thing that jumps out at me when I quickly scan your xml is the fact that you have this SQL expressionADDRESS LIKE '%[value]%' and then you have the field name listed as ADDRES (notice on less S).
Jay, If your APN field is a numeric field than you need to adjust your SQL Expression for that use case:<value prompt="Example: 181001490000 ">APN LIKE %[value]%</value> Notice no single quotes tells the SQL that you are working with numbers.Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow these steps as shown in the below graphic:
Thanks Robert it worked.Thank you for all your help...I just have one last thing.The show result on grid always pop up automatically after each search.Is there a way to disable it, until I click the "Show Results on Grid" button"Thanks.
<table> <name>Customers</name> <token/> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <url>http://gisweb:6080/arcgis/rest/services/detailed/MapServer/84</url> <expressions> <expression alias="Location Code" textsearchlabel="Search Service by Location Code [ Example: 232410901 ]:" isvaluerequired="true"> <values> <value prompt="Example: 232410901" isvaluerequired="true" >xyz.METER.LOCATION_CODE = '[value]'</value> </values> </expression> <expression alias="Customer Name" textsearchlabel="Search Customer by Customer Name [ Example: FROST ]:" isvaluerequired="true"> <values> <value prompt="Example: FROST" isvaluerequired="true" >upper(xyz.METER.CUSTOMER_NAME) LIKE upper('[value]%')</value> </values> </expression> <expression alias="Billing Acct #" textsearchlabel="Search Customer by Account # [ Example: 487788 ]:" isvaluerequired="true"> <values> <value prompt="Example: 487788" isvaluerequired="true" >xyz.METER.ACCOUNT_NUMBER = '[value]'</value> </values> </expression> <expression alias="Service Street Address" textsearchlabel="Search Customer by Street Address [ Example: 850 COMMERCE RD ]:" isvaluerequired="true"> <values> <value prompt="Example: 850 COMMERCE RD" isvaluerequired="true" >upper(xyz.METER.SERVICE_ADDRESS_1) = upper('[value]')</value> </values> </expression> </expressions> <titlefield>xyz.METER.CUSTOMER_NAME</titlefield> <fields all="false"> <field name="xyz.METER.LOCATION_CODE"/> <field name="xyz.METER.ACCOUNT_NUMBER" gridfield="true" /> <field name="xyz.METER.CUSTOMER_NAME" gridfield="true" /> <field name="xyz.METER.SERVICE_ADDRESS_1" gridfield="true" /> <field name="xyz.METER.SERVICE_ADDRESS_2" gridfield="true" /> <field name="xyz.METER.SERVICE_CITY_STATE_ZIP" gridfield="true" /> <field name="xyz.METER.HOME_PHONE" gridfield="true" /> <field name="xyz.METER.ACCOUNT_STATUS" gridfield="true" /> </fields> <links/> </table> Table in question: Layer: xyz.METER (ID: 84) Name: xyz.METER Display Field: CUSTOMER_NAME Type: Table Geometry Type: N/A Description: null Definition Expression: Copyright Text: N/A Default Visibility: false MaxRecordCount: 1000 Supported Query Formats: JSON, AMF Supports Advanced Queries: true Supports Statistics: true Extent: Drawing Info: N/A HasZ: false HasM: false Has Attachments: false HTML Popup Type: esriServerHTMLPopupTypeNone Type ID Field: null Fields: OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID ) LOCATION_CODE ( type: esriFieldTypeString , alias: Location Code , length: 30 ) METER_NUMBER ( type: esriFieldTypeString , alias: Meter Number , length: 30 ) CUSTOMER_NAME ( type: esriFieldTypeString , alias: Customer Name , length: 40 ) ACCOUNT_NUMBER ( type: esriFieldTypeString , alias: Account Number , length: 20 ) ACCOUNT_STATUS ( type: esriFieldTypeString , alias: Account Status , length: 10 ) BILLING_ADDRESS_1 ( type: esriFieldTypeString , alias: Billing Address 1 , length: 40 ) BILLING_ADDRESS_2 ( type: esriFieldTypeString , alias: Billing Address 2 , length: 40 ) BILLING_CITY_STATE_ZIP ( type: esriFieldTypeString , alias: Billing City, State, Zip , length: 40 ) SERVICE_DESC ( type: esriFieldTypeString , alias: Service Description , length: 40 ) SERVICE_ADDRESS_1 ( type: esriFieldTypeString , alias: Service Address 1 , length: 40 ) SERVICE_ADDRESS_2 ( type: esriFieldTypeString , alias: Service Address 2 , length: 40 ) SERVICE_CITY_STATE_ZIP ( type: esriFieldTypeString , alias: Service City, State, Zip , length: 40 ) HOME_PHONE ( type: esriFieldTypeString , alias: Home Phone Number , length: 40 ) SUBDIVISION ( type: esriFieldTypeString , alias: SUBDIVISION , length: 40 ) BLOCK_NUMBER ( type: esriFieldTypeString , alias: Block Number , length: 10 ) LOT_NUMBER ( type: esriFieldTypeString , alias: Lot Number , length: 10 ) APARTMENT ( type: esriFieldTypeString , alias: Apartment Number , length: 10 ) SUITE ( type: esriFieldTypeString , alias: Suite Number , length: 10 ) ON_DATE ( type: esriFieldTypeDate , alias: ON_DATE , length: 36 ) SECTION_ID ( type: esriFieldTypeString , alias: Line Section ID , length: 20 ) PRIMARY_METER ( type: esriFieldTypeString , alias: Primary Meter? , length: 1 , Coded Values: , ) SERVICE_LOCATION_ID ( type: esriFieldTypeInteger , alias: Service Location ID (Foreign Key) ) CAYENTA_LOC_REC_NO ( type: esriFieldTypeString , alias: CAYENTA_LOC_REC_NO , length: 20 ) ROUTE_NO ( type: esriFieldTypeString , alias: Route No , length: 10 ) SEQ_NO ( type: esriFieldTypeString , alias: Sequence No , length: 10 ) CYCLE_NO ( type: esriFieldTypeString , alias: Cycle No , length: 10 ) JDE_WO_ID ( type: esriFieldTypeString , alias: JDE_WO_ID , length: 20 ) DATE_INSERVICE ( type: esriFieldTypeDate , alias: Date Inservice , length: 36 ) WIRE_COUNT ( type: esriFieldTypeInteger , alias: Wire Count ) SERVICE_STATUS ( type: esriFieldTypeString , alias: Service Status , length: 10 ) LOCATION_CLASS ( type: esriFieldTypeString , alias: Location Class , length: 10 ) LOCATION_SUBCLASS ( type: esriFieldTypeString , alias: Location Subclass , length: 10 ) METER_BILL_CODE ( type: esriFieldTypeString , alias: Meter Bill Code , length: 10 ) KW_DEMAND ( type: esriFieldTypeString , alias: KW Demand , length: 20 ) KWH_CONSUMED ( type: esriFieldTypeString , alias: KWH Consumed , length: 20 ) READ_DATE ( type: esriFieldTypeDate , alias: Read Date , length: 36 ) BILLING_CYCLE_DAYS ( type: esriFieldTypeString , alias: Billing Cycle Days , length: 10 ) CRITICAL_LOAD ( type: esriFieldTypeString , alias: Critical Load , length: 7 ) SPOT_LOAD ( type: esriFieldTypeString , alias: Spot Load , length: 5 , Coded Values: , ) METER_TYPE ( type: esriFieldTypeString , alias: Meter Type , length: 15 ) METER_MULTIPLIER ( type: esriFieldTypeString , alias: Meter Multiplier , length: 5 ) TAX_DISTRICT ( type: esriFieldTypeString , alias: Tax District , length: 5 ) METER_COMMENTS ( type: esriFieldTypeString , alias: Meter Comments , length: 100 ) WORKREQUESTID ( type: esriFieldTypeString , alias: Work Request ID , length: 20 ) DESIGNID ( type: esriFieldTypeString , alias: Design ID , length: 20 ) WORKLOCATIONID ( type: esriFieldTypeString , alias: Work Location ID , length: 20 ) WORKFLOWSTATUS ( type: esriFieldTypeInteger , alias: Work Flow Status , Coded Values: [0: None] , [1: In Design] , [2: Pending Approval] , ...5 more... ) WORKFUNCTION ( type: esriFieldTypeInteger , alias: Work Function , Coded Values: [0: In-Service] , [1: Install] , [2: Remove] , ...5 more... ) HOUSE_NO ( type: esriFieldTypeString , alias: House Number , length: 18 ) STREET_PFX_DIR ( type: esriFieldTypeString , alias: Street Prefix Direction , length: 5 , Coded Values: , , [NE: North East] , ...5 more... ) STREET_NM ( type: esriFieldTypeString , alias: Street Name , length: 40 ) STREET_NM_SFX ( type: esriFieldTypeString , alias: Street Name Suffix , length: 6 , Coded Values: [ALY: Alley] , [ANX: Annex] , [ARC: Arcade] , ...196 more... ) STREET_SFX_DIR ( type: esriFieldTypeString , alias: Street Suffix Direction , length: 5 , Coded Values: , , [NE: North East] , ...5 more... ) SEC_ADDR_ID ( type: esriFieldTypeString , alias: Secondary Address (unit) , length: 5 , Coded Values: [APT: Apartment] , [BLDG: Building] , [BOX: Box] , ...12 more... ) SEC_ADDR_RANGE ( type: esriFieldTypeString , alias: Secondary Address Range , length: 18 ) SPECIAL_DIRECTIONS ( type: esriFieldTypeString , alias: Special Directions , length: 50 ) BAD_DOG ( type: esriFieldTypeString , alias: Bad Dog , length: 10 ) TECH_SERV_MULTIPLIER ( type: esriFieldTypeString , alias: Tech Services Multiplier , length: 10 ) FLEXNET_ID ( type: esriFieldTypeString , alias: FLEXNET_ID , length: 20 ) Relationships: Service Location (0) -- Related To: De-Energized Service Locations (8) Supported Operations: Query Query Related Records Generate Renderer Return Updates
I've encountered a similar issue, and this type of thing is really not my forte. Any help would be greatly appreciated.
<name>Contracts</name>
<url>http://bvlwbip74.conoco.net/ArcGIS/rest/services/RPA_Maps/RPA_Land/MapServer/0</url>
<expressions>
</expressions>
<graphicalsearchlabel>Use one of the graphical search tools to select</graphicalsearchlabel>
<field name="CONTRACT" alias="Contract Number" gridfield="true"/>
<field name="STATE" alias="State" gridfield="true"/>
<field name="COUNTY" alias="County" gridfield="true"/>
<field name="PROSPECT" alias="Prospect" gridfield="true"/>
<field name="TYPE" alias="Type" gridfield="true"/>
<field name="AGENCY_NO" alias="Agency Number" gridfield="true"/>
<field name="EFF_DTE" alias="Effective Date" dateformat="MM/DD/YYYY" gridfield="true"/>
<field name="EXP_DTE" alias="Expiration Date" dateformat="MM/DD/YYYY" gridfield="true"/>
<field name="Link" alias="LiveLink" hyperlinkgridfield="true"/>
<field name="LEGACY_NO" gridfield="true" gridfieldonly="true"/>
<field name="DESCRIPTION" gridfield="true" gridfieldonly="true"/>
<field name="GROSS_ACRES" gridfield="true" gridfieldonly="true"/>
<field name="NET_ACRES" gridfield="true" gridfieldonly="true"/>
<field name="PROSP_NO" gridfield="true" gridfieldonly="true"/>
<field name="ASSET_AREA" gridfield="true" gridfieldonly="true"/>
<field name="BU" gridfield="true" gridfieldonly="true"/>
<field name="HERITAGE_CO" gridfield="true" gridfieldonly="true"/>
<field name="EXP_DATE" gridfield="true" dateformat="MM/DD/YYYY" gridfieldonly="true"/>
<field name="EFF_DATE" gridfield="true" dateformat="MM/DD/YYYY" gridfieldonly="true"/>
<field name="GRP_CODE" gridfield="true" gridfieldonly="true"/>
<field name="STAGE" gridfield="true" gridfieldonly="true"/>
<field name="CNTY_CODE" gridfield="true" gridfieldonly="true"/>
<field name="FILE_NUM" gridfield="true" gridfieldonly="true"/>
<field name="SDE_DATE" gridfield="true" dateformat="MM/DD/YYYY" gridfieldonly="true"/>
<field name="FILE_KEY" gridfield="true" gridfieldonly="true"/>
</fields>
<icon isfield="false">assets/images/Livelink.gif</icon>
<linkfield>Link</linkfield>
<zoomscale>50000</zoomscale>
</layer>
Scott,
Most of the time people encounter this error due to the incorrect spelling or CaSe of a field name in their list of fields. You need to double check the names of all the fields you have listed and their CaSe to see if they match your rest service directory. I can help with this part because your rest endpoint is not accessible to me.
Thanks Robert.
I found a few that were not correct and made the changes, but am still getting the errorThis is how the fields appear in the rest endpoint:
Fields:
Link and SDE_DATE were the 2 I changed in the code to match the rest list.
