Are you setting the layer's type to "tiled"?See:http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Layer_tag/01m30000000p000000/
Meade and Mehrshad, Here is an image of the topo map take using both the Flex API and JS API and they are identical in quality.[ATTACH=CONFIG]16830[/ATTACH]Mehrshad, Your likely issue is that all your tiled/cached maps have to be in the same spatial reference and have the same levels of display if you are going to be able to see them together in the map.
Thank you for your response. When I set the layer's type to "tiled", the layer does not draw! Only when the layer type is set to "dynamic", it draws! Thanks for your help.
