import arcpy mxdDocumentPath = r"C:\tmp\MapProjects\DataDrivenPages.mxd" mxd = arcpy.mapping.MapDocument(mxdDocumentPath) indexLayer = r"C:\tmp\Test.gdb\PolygonFeatures" #iterate through data driven pages for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = pageNum #check first data frame from Layuot (if you have more than one use wilcard, eg. ListDataFrames(mxd,"Layers") df = arcpy.mapping.ListDataFrames(mxd)[0] #get the scale of current page (the scale taken is not rounded so first define round factor) #define round factor: -2: round scale to 100, -1: round scale to 10, etc. roundFactor = -2 pageScale = round(df.scale, roundFactor) #take some identificator of feature in current page, eg. OBJECTID, FID, etc. ddpFeatureID = mxd.dataDrivenPages.pageRow.OBJECTID #open UpdateCursor on one row of indexLayer #if you use TEXT field as an identificator use '"textField" = ' + "'" + str(ddpFeatureID) + "'" as a WHERE clause updCur = arcpy.UpdateCursor(indexLayer, '"OBJECTID" = ' + str(ddpFeatureID)) for updCurRow in updCur: #update Scale field of DOUBLE type (create this field before running script) updCurRow.setValue("Scale", pageScale) updCur.updateRow(updCurRow) del updCur
I crafted some code which may be helpful.First, create Scale field of double type in your data. Then adjust pathes and rounding in script:import arcpy mxdDocumentPath = r"C:\tmp\MapProjects\DataDrivenPages.mxd" mxd = arcpy.mapping.MapDocument(mxdDocumentPath) indexLayer = r"C:\tmp\Test.gdb\PolygonFeatures" #iterate through data driven pages for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = pageNum #check first data frame from Layuot (if you have more than one use wilcard, eg. ListDataFrames(mxd,"Layers") df = arcpy.mapping.ListDataFrames(mxd)[0] #get the scale of current page (the scale taken is not rounded so first define round factor) #define round factor: -2: round scale to 100, -1: round scale to 10, etc. roundFactor = -2 pageScale = round(df.scale, roundFactor) #take some identificator of feature in current page, eg. OBJECTID, FID, etc. ddpFeatureID = mxd.dataDrivenPages.pageRow.OBJECTID #open UpdateCursor on one row of indexLayer #if you use TEXT field as an identificator use '"textField" = ' + "'" + str(ddpFeatureID) + "'" as a WHERE clause updCur = arcpy.UpdateCursor(indexLayer, '"OBJECTID" = ' + str(ddpFeatureID)) for updCurRow in updCur: #update Scale field of DOUBLE type (create this field before running script) updCurRow.setValue("Scale", pageScale) updCur.updateRow(updCurRow) del updCur
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
