@ErikE : It looks like it should be working. In my code, when I click my print button, it runs the following to set up the map: PDFExporter PDFNew = new PDFExporter(); PDFNew.SetMap(MyMap);..continue on my merry way...
private void Map2PDF_Click(object sender, RoutedEventArgs e) { Map2PDF map2pdf = new Map2PDF(); map2pdf.Show(); }
<esri:Map x:Name="Map" Loaded="Map_Loaded" Extent="-15000000,2000000,-7000000,8000000">
using ESRI.ArcGIS.Client; using CMC_Viewer.Utils; public interface IParentDialog { void SetStatus(string sStatus); void TaskCompleted(bool bSuccessful); } namespace CMC_Viewer.Views { public partial class ExportPDF : ChildWindow, IParentDialog { private PDFExporter _Exporter; private bool _bTwoStage = false; private bool _bFirst = false; private const string sOKMsg = "OK"; private const string sFailedMsg = "Failed"; private const string sStartMsg = "Click 'Start' to generate image."; private const string sStartLabel = "Start"; private const string sFinishMsg = "Click 'Finish' to create PDF."; private const string sFinishLabel = "Finish"; public ExportPDF() { InitializeComponent(); _Exporter = new PDFExporter(); _Exporter.SetParent(this); lblStatus.Content = sOKMsg; btnOK.Content = sStartLabel; btnOK.Click += btnOK_Click; chkExportOption.Checked += chkExportOption_Checked; chkExportOption.Unchecked += chkExportOption_Unchecked; } // Methods called by the MainPage public void SetMap(Map TheMap) { _Exporter.SetMap(TheMap); } public void AddElement(UIElement TheElement) { _Exporter.AddElement(TheElement); }
<controls:ChildWindow x:Class="CMC_Viewer.Views.ExportPDF" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:sdk="http://schemas.microsoft.com/winfx/2006/xaml/presentation/sdk" xmlns:controls="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls" mc:Ignorable="d" d:DesignHeight="60" d:DesignWidth="280" >
private void Map2PDF_Click(object sender, RoutedEventArgs e) { /* // Don't need the ExportPDF dialog anymore CMC_Viewer.Views.ExportPDF map2pdf = new CMC_Viewer.Views.ExportPDF(); map2pdf.SetMap(this.Map); map2pdf.Show(); * */ // Display save-as dialog SaveFileDialog dialog = new SaveFileDialog(); dialog.Filter = "PDF|*.pdf"; if (!dialog.ShowDialog().Value) { return; } // Create a new dynamic layer from the same map service as current tiled layer ArcGISTiledMapServiceLayer tiled = this.Map.Layers[0] as ArcGISTiledMapServiceLayer; ArcGISDynamicMapServiceLayer dynamic = new ArcGISDynamicMapServiceLayer() { Url = tiled.Url, ImageFormat = ArcGISDynamicMapServiceLayer.RestImageFormat.JPG }; // When the dynamic layer has initialized create the in-memory PDF document dynamic.Initialized += (a, b) => { dynamic.GetUrl(this.Map.Extent, (int)this.Map.ActualWidth, (int)this.Map.ActualHeight, delegate(string url, int width, int height, Envelope extent) { // Download a new image of identical to what is currently displayed in the map WebClient webClient = new WebClient(); webClient.OpenReadCompleted += (c, f) => { // Use the dispatcher to force execution in the UI thread Dispatcher.BeginInvoke(delegate() { // Create the PDF document, set document information properties PdfDocument document = new PdfDocument(); document.Info.Title = "Map"; // Create a new page with the same dimensions as the browser map PdfPage page = new PdfPage(document) { Height = new XUnit(this.Map.ActualHeight, XGraphicsUnit.Presentation), Width = new XUnit(this.Map.ActualWidth, XGraphicsUnit.Presentation) }; document.Pages.Add(page); // Create a graphics object for writing to the page XGraphics graphics = XGraphics.FromPdfPage(page); // Add the map image to the page XImage image = XImage.FromStream(f.Result); graphics.DrawImage(image, 0d, 0d); // Save the PDF document to the user specified filename document.Save(dialog.OpenFile()); // Notify the user that we're done MessageBox.Show("Map saved to '" + dialog.SafeFileName + "'"); }); }; webClient.OpenReadAsync(new Uri(url)); }); }; dynamic.Initialize(); }
We ended up going pretty lean on the exporter. The method we implemented is as followsprivate void Map2PDF_Click(object sender, RoutedEventArgs e) { /* // Don't need the ExportPDF dialog anymore CMC_Viewer.Views.ExportPDF map2pdf = new CMC_Viewer.Views.ExportPDF(); map2pdf.SetMap(this.Map); map2pdf.Show(); * */ // Display save-as dialog SaveFileDialog dialog = new SaveFileDialog(); dialog.Filter = "PDF|*.pdf"; if (!dialog.ShowDialog().Value) { return; } // Create a new dynamic layer from the same map service as current tiled layer ArcGISTiledMapServiceLayer tiled = this.Map.Layers[0] as ArcGISTiledMapServiceLayer; ArcGISDynamicMapServiceLayer dynamic = new ArcGISDynamicMapServiceLayer() { Url = tiled.Url, ImageFormat = ArcGISDynamicMapServiceLayer.RestImageFormat.JPG }; // When the dynamic layer has initialized create the in-memory PDF document dynamic.Initialized += (a, b) => { dynamic.GetUrl(this.Map.Extent, (int)this.Map.ActualWidth, (int)this.Map.ActualHeight, delegate(string url, int width, int height, Envelope extent) { // Download a new image of identical to what is currently displayed in the map WebClient webClient = new WebClient(); webClient.OpenReadCompleted += (c, f) => { // Use the dispatcher to force execution in the UI thread Dispatcher.BeginInvoke(delegate() { // Create the PDF document, set document information properties PdfDocument document = new PdfDocument(); document.Info.Title = "Map"; // Create a new page with the same dimensions as the browser map PdfPage page = new PdfPage(document) { Height = new XUnit(this.Map.ActualHeight, XGraphicsUnit.Presentation), Width = new XUnit(this.Map.ActualWidth, XGraphicsUnit.Presentation) }; document.Pages.Add(page); // Create a graphics object for writing to the page XGraphics graphics = XGraphics.FromPdfPage(page); // Add the map image to the page XImage image = XImage.FromStream(f.Result); graphics.DrawImage(image, 0d, 0d); // Save the PDF document to the user specified filename document.Save(dialog.OpenFile()); // Notify the user that we're done MessageBox.Show("Map saved to '" + dialog.SafeFileName + "'"); }); }; webClient.OpenReadAsync(new Uri(url)); }); }; dynamic.Initialize(); }We found that the size of the map to be exported has to be set better than in other examples. Anyway, the code above produces a high quality map.
FYI, the PDF exporter download has included an example user control since November. I've never seen a problem with tiled, dynamic, or graphic layers.http://www.pierssen.com/arcgis10/silverlight.htm
This is the best way to create a pdf with a silverlight GIS web application. We have modified this sample to work in our environment with much success.http://www.arcgis.com/home/item.html?id=8f16fdeef39c46b3952002b2d85ea5deThe maps produced, since you print to pdf from the source data, are high quality, not the 96 dpi ones you get from REST.
using PdfSharp.Pdf; private void PDFbutton_MouseLeftButtonUp(object sender, MouseEventArgs e) { SaveFileDialog savePDF = new SaveFileDialog(); savePDF.Filter = "PDF file format|*.pdf"; savePDF.DefaultExt = ".pdf"; if (savePDF.ShowDialog() == true) { System.IO.Stream PDFstream = savePDF.OpenFile(); PDFExporter PDFNew = new PDFExporter(); PDFNew.SetMap(myMap); PDFNew.SetOutputStream(PDFstream); PDFNew.DoExport(); } }
Private Sub Print_Click(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) Dim savePDF As New SaveFileDialog() savePDF.Filter = "PDF file format|*.pdf" savePDF.DefaultExt = ".pdf" If savePDF.ShowDialog() = True Then Dim PDFstream As System.IO.Stream = savePDF.OpenFile() Dim PDFNew As New PDFExporter() PDFNew.SetMap(MyMap) PDFNew.SetOutputStream(PDFstream) PDFNew.DoExport() End If End Sub
patrickbrooke ANY help on how to integrate that into a Silverlight app that is using VB. This forum entry has confused me even more as I am seeign a few different ways to do it...I love the option to choose a map title etc... Can you help by informing how to incorporate into silverlight? Thanks
List<GPParameter> jobParameters = new List<GPParameter>(); jobParameters.Add(new GPDouble("xMin", boundingExtent.XMin)); jobParameters.Add(new GPDouble("yMin", boundingExtent.YMin)); jobParameters.Add(new GPDouble("xMax", boundingExtent.XMax)); jobParameters.Add(new GPDouble("yMax", boundingExtent.YMax)); jobParameters.Add(new GPString("Spatial_Reference", MyMap.SpatialReference.WKID.ToString())); jobParameters.Add(new GPDouble("Map_Scale", Mapscale)); jobParameters.Add(new GPString("Visiblelayers", "None")); jobParameters.Add(new GPString("Layout", theTemplate)); jobParameters.Add(new GPBoolean("Include_Attributes", false)); jobParameters.Add(new GPString("Map_Title", pdfTitle)); jobParameters.Add(new GPString("PointGraphics", "")); jobParameters.Add(new GPString("PolyGraphics", ""));
Geoprocessor ExportTask = new Geoprocessor("http://......../rest/services/ExportPDF_GP/GPServer/ExportToPDF"); ExportTask.JobCompleted += new EventHandler<JobInfoEventArgs>(ExportTask_JobCompleted); ExportTask.Failed += new EventHandler<TaskFailedEventArgs>(ExportTask_Failed); ExportTask.SubmitJobAsync(jobParameters);
