I want to change check box message appearing on Templetepicker in the Edit Widget. Now there is a default layer called"Fires" on the Templete, if I uncheck the "Fires" layer, there will be information like"Fires feature layer is either not visible or out of scale range". What if I need to change this message to others, such as "You unchecked the Fires layer"? Thanks!
