The json generated from the sites endpoint is an incomplete list of layers offered on our site. I'm seeing 4 layers when I should see 40. This problem started around April 19th. Graham Hudgins Thomas Hervey
Endpoint: https://opendata.arcgis.com/api/sites/<id>/datasets.json
Our page: Open Data Site
That endpoint is most likely no longer supported. You can take a look at your site's sitemap (which is XML) https://gisdatacatalog-spokanecounty.opendata.arcgis.com/sitemap.xml and see listed datasets there. We don't have a /sites API endpoint in our current Hub API (v3), but you may be able to query datasets associated with your site in our v2 API (documentation here: https://hub.arcgis.com/api/v2/sites/%7B:id%7D?{include} ). I unfortunately wasn't able to find your site on the v2 sites endpoint, but it may be there if you do a bit of digging.
Thanks for your reply. I suppose I could parse the sitemap but was hoping to stick with json using an official api.
I was using v2 to query for datasets. API Documentation (unofficial?) is here and here as revealed by Courtney Claessens way back in 2017. I suppose I could hack through http://gisdatacatalog-spokanecounty.opendata.arcgis.com/data.json but it isn't pretty.
Patrick Hammons it looks like you might have an answer. How might I use v3 to get a json of my site's datasets? I see your gist at v3.md · GitHub but I' not sure how to use it to get info on my site. I don't see a siteid parameter in the docs. When I try this I get everything hosted by ESRI. Thanks for any help you can provide.
I don't think our v3 API has a quick way to query datasets associated with a site, but I'll investigate. You can view all the datasets from an organization instead by using a filter with your orgId and a large page size likehttps://hub.arcgis.com/api/v3/datasets?filter[orgId]=yourOrgId&page[size]=1000
Thanks for sharing that URL syntax. I gave that a shot but didn't get much.
{ "data": [], "meta": { "apiRoot": "http://hub.arcgis.com/api/v3/", "queryParameters": { "filter": { "orgId": "xyz", "isCancelled": "eventsEq(false)", "status": "not(private,draft,planned)", "endDate": "eventsBefore(1591307427179)" } }, "request": "http://hub.arcgis.com/api/v3/datasets?filter[orgId]=xyz", "resourceRoot": "http://hub.arcgis.com/api/v3/datasets", "stats": { "totalCount": 0, "count": 0, "aggs": {} }, "page": { "start": 1, "size": 10, "nextStart": -1 }, "took": 5, "total": 0, "datasetsMatching": { "onlySemanticFields": [], "onlyNonSemanticFields": [], "both": [] } }, "links": {}}
I spoke with Premium Support. Looks like I was referencing the wrong ID. Thanks again, Thomas Hervey
