I'm not sure how to move a feature while editing. I can add and delete but can't move the point. I've looked at the properties and full editing has been enabled. I can't figure out how to move the feature to another location.
thank you!
The issue is with the m values being enabled on the feature class when the feature class was created. The feature service then gets the property m values: true. You can see this at the REST endpoint of the feature service: HasM: true. The map viewer prevents the editing of geometries when the m values have been enabled b/c they do not support editing m values and the feature would lose the values on features if you edited there geometry in the map viewer.
this happens sometimes if the features are symolized based on an attribute, if you change the symbol to a location only type it works better
With editing enabled try clicking on the "Edit Button" located between "Add" and "Basemap". This should bring up a screen allowing you to add data points. While this screen is active you should be able to relocate existing points.
When you click edit on the feature in the popup, click and grab the feature with your mouse and then you can drag the point feature to that new location.
Same issue here and none of the above seems to help. I can edit, create and delete but unable to move a feature. The only to move the feature is to bring it back to my desktop and work on it (slow) or move it in Collector.
I know you said you've checked the permissions but just to verify...
On the feature class, click on edit and look under Properties > Editing section.
Make sure that Add, update and delete features is the option selected.
Everything looks fine here:
I've found the same issue, but only with line features. I can edit/move a polygon feature in the same feature service, but the only way I can interact with a line feature is editing the attributes.
HOWEVER
I can edit that line feature using the Collector app on my Android.
I would say it appears to be a bug.
I can edit lines, can you share your map with my test account russrob and I can see if I can repro this issue. Also what browser are you using?
Thanks
Russ
Here's the link. The features are only demo for showing mobile mapping capabilities to another office so all of the features on the map are essentially meaningless. Feel free to edit however you like.
https://lehighgis.maps.arcgis.com/home/webmap/viewer.html?webmap=37c0c4eeb2c348b4bc97c2d247e2db66
Well, I see SOMEONE has tried to edit an hour or 2 ago. They added a feature, but no other lines have moved.
That was me checking out your map and services. Just looking into your services and I see that m values are set to true. I think this is the reason why the geometry editing is being blocked. Probably b/c editing the geometry would cause m values to be lost for that feature but I am just waiting to confirm this with a colleague right now.
I have the same problem. I need to move an area. Hope you find the solution!
It looks like the issue above was caused by M values being required on the data. If you navigate to your rest endpoint? do you see the following parameter HasM: true.?
-Kelly
I'm having the same issue, Portal 10.3 editable feature service, HasM:false. I did not add the feature service to Portal as an item, just added the layer directly from our server.
Any thoughts?
Has this been resolved for anyone? I've checked all of the suggestions, Enable Editing is on and HasM: False.
Yet I cannot update.
I'm serving the point feature classing using ArcGIS Portal 10.4, the data are in a verisioned gdb and working with the map in an app. Anything?
Nadine
I found the issue. In order to select the feature and see the attribute popup, you must drag select it with the tool, but if you want to move it, you need to just single click on it, then move it.
Thanks Russell. With the feature selected you will see the cursor change to the 'hand' when you hover over the line - then you can click and drag
I'm using a hosted feature layer (point layer) that was published from ArcGIS Pro, M not enabled (on desktop, I don't know how to check if M is enabled online?). When opening a web map, user can update attributes and add new data - these can be saved (and in edit tab "undo" button is active when change is made). User can also drag a point to a new location - but this can't be saved, "undo" not active, when exiting the map, all changes are lost... Is there a solution to this? Has anyone had similar experience?
Hi all, I am also having trouble updating features through Web App Builder. M is set to false, capabilities are Layer:
I'm also having a similar issue. The layer whose features I'm trying to move has HasM: false. The strange thing is that I can move some features in the layer but not other features. Also, some features will display the little hand when you hover over them indicating that they can be moved (and they can), while other features require that you first display the pop-up then the little white hand appears (and can then move them), while other features can't be moved at all...
Hi All, My situation is exactly like Richard Syme's, except that I'm working with a hosted feature service. It's a pain to have to delete a feature and recreate it in the proper position! Anyone with new discoveries?
ESRI isn't planning to support moving m-aware points any time soon. GO HERE to vote the idea up and get ESRI's attention Move m-aware points inside a web application
Move m-aware points inside a web application - (https:)//community.esri.com/ideas/15741-move-m-aware-points-inside-a-web-application
bump
Bump?
We are not trying to move M-aware points, we are trying to move points where HasM: false.
This post began in January 2016. Its now January 2019 and still no resolution to this? ESRI if you are out there, not being able to edit features is kind of a big problem!
I'm having same issues. Cant move point features using the editing tools in my app. I have an editable feature service layer. No M values. Loaded into a web map I used to create a web app. Within the app, I cant move geometry. Tried edit and smart edit widgets. Feature layer settings are set to edit, layer shared, etc. Seems like an issue with bad outdated editing widgets that don't work.
Not everyone on this thread, my friend.
I'd suggest getting in touch with tech support to look into the specific issue if the suggestions on this post aren't helping to resolve the issue. A tech support analyst can dedicate time and testing to your specific dataset to get to the bottom of the issue in a timely manner.
REMINDER
I managed to find a solution for myself. Here's how.
I had the same issue: M values were disabled but points still wouldn't move. I tried removing labels from points in my webmap --> points move. I tried re-enabling the labels -->points won't move. So the solution for me was to remove the labels from the editable webmap.
I found that if a polygon feature is over the point feature that I can not edit the geometry of the lower layer. check the layer list and turn off layers above it and see if you can edit it then.
check layer list and turn off layers above the layer you are trying to edit. I found that I couldnt edit a point features geometry that was bellow a Parcel polygon feature on the layer list unless the parcel was either moved below the point layer or turned off.
This suggestion worked for me -- thanks!
Exact same issue here with a point layer. All settings set properly/as noted above, no presence of M/Z values, cross-validated in IE11/Edge/Chrome/Firefox/Edge (Chromium-based), and all fail to edit/move the point data.
It is only editable using ArcGIS Pro/ ArcMap on desktop.
Its been a while since I had this issue but I did get it to work. I believe what worked for me was what Frank Vignati said in this post. Remove any attribute based symbology in the webmap you want to use for your application.
I wish that applied here. It is a simple symbology, Location (Single Symbol), with no filters, no attributes-based styling, no labeling, no pop-ups, and lives in its own map with no other layers than the required basemap.Thanks for your suggestion, however.
Same issue on ArcGIS online. HasZ: false
HasM: false
My solution was this: Move non-editable layers to the bottom of the layer list.
I always had HasM: false.
TLDR; I had a web map with layers from multiple hosted feature services (HFS). Some services where editable and others where not. I noticed if I opened the editable HFS within it's own new web map, I could move points around with no problem. I could NOT move points in the original web map with all the services. I was comparing JSONs, nothing much there that stood out, but out of sheer luck I turned off the visibility of the non-editable layers and I was able to move my editable points. But I needed to view non-editable layers, so I moved them to the bottom of the list and vualá!
Using the Smart Editor, you can edit geometry by entering the coordinates. I altered the coordinate tool (default) to use the Web Mercator (no TKWKID needed)
1) select item in smart editor.
2) identify the correct location with the coordinate tool in the lower left corner. highlight and copy the coordinates
3) choose the xy option under edit geometry
4) paste the coordinates. cut the longitude, paste it in the next field.
5) this moves the point. save edit.
with degrees, but switching to lat then long in the display for convenience, and also adding more numerals for precision. This allows for a quicker edit.
I just achieved this end by creating an empty shapefile with m-Values = TRUE, and then copied all of the data from my original dataset into the new featureclass. Uploaded to AGOL and selected with the point-click method. In my case, I have over 1000 points in the same location so after I selected the pile of points, I had to choose which record to edit from a dialog box. I would really like to be able to select a point from the attribute table but I guess that's not a thing yet. As long as I matched up the OID, I can accurately choose which feature I want to relocate
