Jeremy, I am not sure why you are getting this error. When you look at this layer in the REST Service directory for you see the symbology for the point layer displayed?
//Legend Addition protected function initLegend():void { legendAC = new ArrayCollection([]); ParcelData.getAllDetails(new AsyncResponder(allDtlsResult, allDtlsFault,"ParcelData")); function allDtlsResult(event:AllDetails,lname:String):void { for each (var lDetails:LayerDetails in event.layersDetails){ if(lDetails.id > 0){ if(lDetails.drawingInfo){ //Add the layers name var layName:Object = { lname: lname, id: lDetails.id, otype: "layerName", label: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: null } legendAC.addItem(layName); if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.UniqueValueRenderer) { var uv:UniqueValueRenderer = lDetails.drawingInfo.renderer as UniqueValueRenderer; for (var i:int=0; i<uv.infos.length; i++) { var uvObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: uv.infos } legendAC.addItem(uvObj); } } if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.SimpleRenderer) { var simObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: lDetails.drawingInfo.renderer } legendAC.addItem(simObj); } if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.ClassBreaksRenderer) { var cb:ClassBreaksRenderer = lDetails.drawingInfo.renderer as ClassBreaksRenderer; for (var j:int=0; j<cb.infos.length; j++) { var cbObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: cb.infos } legendAC.addItem(cbObj); } } } } } } function allDtlsFault(event:FaultEvent):void { Alert.show(event.message.toString()); } } //End Legend Addition
Simon, You do need to compile it your self. I have always had bad experiences distributing compiled swfs in the past.
(not the precompiled version)
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
