This widget works fine when layers are listed in the TOC as part of a 'dynamic' layer. But when the same layers are listed individually as 'feature' layers, their labels get ignored. Is there a way to remedy this? Thanks very much, Lewis.
<configuration> <labels> <visibilitylabel>Layer Visibility</visibilitylabel> <legendlabel>Show Dynamic Map Legend</legendlabel> <alphatooltip>Select parent map service to set opacity</alphatooltip> <metadatatooltip>Show details</metadatatooltip> <zoomtoextent>Zoom To Layer Extent</zoomtoextent> <expandall>Expand All Layers</expandall> <collapseall>Collapse All Layers</collapseall> <zoomtomakevisible>Zoom To Make Visible</zoomtomakevisible> <generatinglegendmsg>Generating TOC Legend</generatinglegendmsg> </labels> <tocsettings> <expanded>true</expanded> <showdescriptionbutton>true</showdescriptionbutton> <collapselegends>false</collapselegends> </tocsettings> <legendtimeout>60</legendtimeout> <excludelayers > <excludelayer mapservice="Hybrid"></excludelayer> <excludelayer mapservice="Map"></excludelayer> <excludelayer mapservice="Satellite"></excludelayer> <excludelayer mapservice="IDL Test"></excludelayer> <excludelayer mapservice="ETeam"></excludelayer> <excludelayer mapservice="Base"></excludelayer> <!--<excludelayer mapservice="Radar"></excludelayer>--> <excludelayer mapservice="MapIt">6,7</excludelayer> <!-- <excludelayer mapservice="Parcel Data">19,20,21</excludelayer>--> </excludelayers> <excludegraphiclayers>true</excludegraphiclayers> <excludebasemaplayers>true</excludebasemaplayers> </configuration>
Nathan, No I have no idea... All my map services are displayed in the same order as listed in the REST Service directory. The only difference is that I am on ArcGIS Service pack 4 and you are still on 2.
Adi, You can find an explaination to that you are seeing explained here:http://forums.arcgis.com/threads/18453-Table-of-Contents-Legend-Widget-for-FlexViewer-2.x?p=186597&viewfull=1#post186597From there you can figure out what you need to do to change one of the labels but by design there will always be two labels.
