# UpdateAngle.py # assumes rectangular polygons # find bearing of longest side # might have trouble with up # 2 June 2011 # Kim Ollivier import arcgisscripting from math import * import datetime gp = arcgisscripting.create(9.3) try: layer = sys.argv[1] except: layer = "stripindex" ws = 'e:/teararoa/nz/current.gdb' gp.workspace = ws if not gp.Exists(ws): print "ws",ws raise Exception rotField = "smap_angle" if not gp.ListFields(layer,rotField): gp.AddField(layer,rotField,"FLOAT") def calcbearing(dPt): ''' calculate bearing of longest side ''' # points pt1 = dPt[1] pt2 = dPt[2] pt3 = dPt[3] # lengths l1 = hypot(pt2[0] - pt1[0],pt2[1] - pt1[1]) l2 = hypot(pt3[0] - pt2[0],pt3[1] - pt2[1]) # bearings b1 = atan2(pt2[1] - pt1[1],pt2[0] - pt1[0]) b2 = atan2(pt3[1] - pt2[1],pt3[0] - pt2[0]) # print "test",round(l1),round(l2),degrees(b1),degrees(b2) # print dPt if l1 > l2 : degree = degrees(b1) else: degree = degrees(b2) bearing = 90.0 - degree if bearing > 90: bearing = bearing - 180 if bearing < -90: bearing = bearing + 180 return bearing cur = gp.UpdateCursor(layer) ##,"ID = 1") row = cur.next() print while row: feat = row.Shape for partNum in range(feat.partCount) : part = feat.getPart(partNum) dPt = {} n = 0 for pt in iter(lambda: part.next(),None): # stops at null pt n+=1 dPt = (pt.X,pt.Y) rotation = calcbearing(dPt) row.setValue(rotField,rotation) row.setValue("LastUpdate",datetime.datetime.now()) # print row.objectid,row.id,row.island,rotation #,dPt cur.updateRow(row) row = cur.next() del row,cur
Has anyone found a Simple solution to this? I am experiencing the same problem
I believe you will still have to rely on a custom python script, although using arcpy geometry objects will likely shorten Kim's script considerably. I'll try to follow up on this.
Here is a 10.1 script you can use to calculate the data driven page rotation angle into a field called calcAngle, for an index feature class of rectangles.
>>> import math ... with arcpy.da.UpdateCursor("RECTANGLE_INDEX_FEATURE CLASS",["SHAPE@","calcAngle"]) as cursor: ... for row in cursor: ... points = [] ... for part in row[0]: ... for pnt in part: ... points.append(pnt) ... lines = [] ... for i in range(1,3): ... lines.append(arcpy.Polyline(arcpy.Array([points,points[i-1]]))) ... if lines[0].length > lines[1].length: ... firstShort = 0 ... else: ... firstShort = 1 ... dx = points[firstShort].X - points[firstShort+1].X ... dy = points[firstShort].Y - points[firstShort+1].Y ... ang = math.degrees(math.atan(dy/dx)) ... row[1] = 360-ang ... cursor.updateRow(row)
Thanks for Darren's script which works perfectly. However I found it requires the 4 points of the polygon be created in a certain order, which might be all right for index polygons created via DDP tool, but in our case we often got the index polygons from other source like CAD design where how it was created not always guaranteed. So I modified Darren's code a bit to allow the calculation work on polygons created in any direction. cheers,
So, Darren's script was originally setup for rectangles, but it looks like your version will work with polygons of any number or vertices. Is that correct?
Secondly, I am not an advanced user and have generally always stayed within the confines of the cookie cutter tools in Arcmap. I don't know how to implement a script in Arcmap. Can anyone refer me to a good thread or link on how to do this so I can actually use this thing?
Thanks All - what a great community this is.
Cheers!
John
Hi Darren,
This looks exactly like what I need however I cannot get the code to work for me. I am trying this in 10.3. I get the error message :Runtime error Traceback (most recent call last): File "<string>", line 6, in <module>TypeError: 'float' object is not iterable
I changed the Feature class and field names to match my layer. ("Release_Grid",["Shape","calcAngle"]
Any suggestions?
Make sure you use "SHAPE@", a special token for the actual geometry.
Just letting you know there is a typo in your script on Line 15, this causes it to fail instantly.
Also, I kept getting an error on Line 22, float division by zero (tan = - dy/dx). I didn't have time to look into it so I used the script posted by Darren in the end. It may be specific to my input, I'm not sure.
Thanks Hayley Hume-Merry pointed out the typo. also John Urbano I just saw your message today. the script only works for 4 point rectangle. However, FYI since then I have been using Minimum Bounding Geometry (by width) tool to work out the rotation angle of polygon of any shape. Just make sure you enabled the Add geometry characteristics as attributes to output option at the bottom of the tool. The output features include a field called MBG_Orientation, which is the orientation of the longer side of the resulting rectangle. I could then derive the rotation angel depends on if the data drive page layout is portrait or landscape.
Still having this issue in July of 2023. Does anyone else have a better solution? The only work around I came up with is after you rotate the strip index polygons, then draw a line snapping to mid point of each polygon, then rerun the strip index tool with 0 overlap, and if necessary do a spatial join with the newly created polygons and field calculate the angle field if you want to update your original strip index polygons.
