I have the portal installed on an EC2 instance with an ELB. I have created the initial admin account and when I click on the sign in tab, I go to a page that says that the initial admin account has been set up but when I hit sign in, I get a 400 "Invalid redirect_uri"(https://myelbdns.elb.amazonaws.com/arcgis/home/signin.html )
Have you set the WebContextURL within the Portaladmin API to "https://myelbdns.elb.amazonaws.com/arcgis"?
Thank you, Jonathan! That worked. I ran into a different issue now. I am trying to configure a highly available portal. I have NFS set up and mounted. When I copy the contents of "arcgis/portal/usr/arcgisportal/content" to the mounted directory and try to change the directory in portal/system/directories/content, I get the following error. Is there something that I missed when copying the files to the mounted directory?
I apologize that this question is completely unrelated to the question above.
Code: 500
No problem. With the user that was used to install Portal, can you reach that location and create a folder or file in it? I haven't run into a situation where that error is thrown and it isn't permissions related.
