Missing the Saturday column in the calendar picker in the Query widget. See below, replicated on different orgs with different datasets. Anyone else experience this, possibly have a fix?
I'm seeing all days when I set up the widget
SO strange! For me, when I set up the query to use the "in between" option, Saturday is not there. When I use the "after" query, like you have shown the calendar picker displays as it should. Weird quirk indeed. Thanks for helping troubleshoot!
I didn't see any problem in setting it up with the "in between" option.
Could the issue be theme specific? Kristin What theme are you using?
Thanks for the suggestion, I think you're right that the issue is theme specific.
The "problem" theme is the Launchpad theme.
I just created another app this morning using the Foldable theme and the calendar picker is working as expected.
Yes, I'm seeing that also in the Launchpad theme
Thanks for helping troubleshoot, Ken!
Kristin & all, another data point... I checked some apps I'm building around 2.12 and Saturday appears correctly in Launchpad; so it seems it is specific to 2.13.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
