I followed the instructions in "Upgrade ArcGIS Projects to SDK 1.1". When I run my project I get the following runtime exceptions. Whatever I did, I could not fix the problem. java.lang.RuntimeException: Unable to start activity ComponentInfo{xyz.xyz.xyz/xyz.xyz.xyz.pages.MapPage}: android.view.InflateException: Binary XML file line #6: Error inflating class com.esri.android.map.MapView android.view.InflateException: Binary XML file line #6: Error inflating class com.esri.android.map.MapView Caused by: java.lang.ClassNotFoundException: com.esri.android.map.MapView in loader dalvik.system.PathClassLoader[/data/app/xyz.xyz.xyz.apk]
Try to go to project properties - java build path - libraries,Remove arcgis libraries,Press button "add library" and chose "arcgis for android library container".
Ah, I misread the "Temporary Fix" that mggl explained above.Ok, if you're getting the "Persistent Contatiner" issue, Don't close Eclipse! Do this instead: 1.) Right Click on your project in the Package Explorer 2.) Select "Close Project" from the pop up menu (It's an option aobut half way down)3.) I guess the graphic is supposed to be a closed folder4.) Right Click on your project again in Package Explorer5.) Select "Open Project"6.) Wow! all the "persistent containers" are gone! (for now!)I feel very silly for not getting this the first time, so I hope it helps somebody else.
Our servers are currently busy or they are down for maintenance. You can try the following: Refresh your browser page Retry the URL address to ensure its accuracy Return in a few minutes and try againIf this problem persists, tell us what you are experiencing through the following contacts: By e-mail: Esri Site Manager By form: Web Site FeedbackWe apologize for the inconvenience.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
