Hello,
We have installed Portal for ArcGIS and would like to use Collector for ArcGIS with our Portal.
I am having issues connecting to our Portal through Collector. Is there a specific URL I need to enter.
Some Info
Any ideas?
Drew
Hi Andrew,
this sounds like a problem with your ssl-certificate. You need to install the certificate of your webserver on your ipad to successfully login. To do so export the Certificate maybe from your browser send the certificate by mail to your ipad an click on it.
If you need more detailed information about how to bring the certificate to your ipad just let me know.
Thanks for the reply Rainer.
We did have all sorts of SSL issues when configuring Portal. We did federate the server and that causes some certificate issues too. I will give your suggestion a try.
Would this be common practice moving forward if it works or should I look at the certificate a little closer?
Thanks again.
Hi Drew,
IT is unfortunally necessary if you are using your own ca or a selfsigned certificate. To avoid this additional steps you need your certificate to be signed by a trusted ca like thawte or startssl.
I hope this helps,
Von: Andrew Timmins
Gesendet: Donnerstag, 20. November 2014 19:42
An: Rainer Spitzer
Antwort an: jive-303489768-y3i-2-9fbh@mail.geonet.esri.com
Betreff: Re: - Portal For ArcGIS - Collector URL?
GeoNet <http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_2vEmGfTv6NF9ysi44XFDLSmAR8EbLECDBSNjtoNhoJc7nstNZq8TQ3olFaKHjkV0JY93Dl1NCEdlSAxI-2BzElmet8Vv9K-2FhATatdwY1vybLkf2fKUlp8Hr3fnyWEFWjVVN7h9p-2BfXNLoWL2-2B8jhCC-2BB-2B4qoW7d5rew2B3uvq9yS1pyQqKZSuhOtm1vP-2FbsFMQSQ8Nl3OUU1W-2FdPmR8mHimm06AItM6llCtIB-2B3etU7C-2FELZQI1S9DejL2tUWLpFvtPfSJ3C49S2R5rAZbYU109fWA2rfevUHp4GLQdxaCVzGZbSaFEF1f4pPXCKN8PNWi>
reply from Andrew Timmins<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2FlQsrl0uao8P-2FakcevGyI3Ifw4yOHHvAIA3gbAJVGi35QgBfOeybhZk7ru1LgAhdA-3D_2vEmGfTv6NF9ysi44XFDLSmAR8EbLECDBSNjtoNhoJc7nstNZq8TQ3olFaKHjkV0JY93Dl1NCEdlSAxI-2BzElmet8Vv9K-2FhATatdwY1vybLkf2fKUlp8Hr3fnyWEFWjVVCGY-2B823Z3ZVwQnx4KacMMten8CqBYR7bbHda6XwmI-2FJE18cpa6zZcup0XRF-2Bc3QrbjLHdLctWlhQNf6EVcxkxlN-2FR0kDPWoGaZLFt73NHVbtdPajBRYBARLcfSFJLKZlfSYLqzj85etfbiQh3GcDNjOaQyZ2F8-2F84SP70rB8zT3SsRBlRDYb4sJbgaNtkhVP> in Portal for ArcGIS - View the full discussion<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEyBFOkFCnASCCZjjSvlKqwNpLqRpHq1i2U-2BZXoilgsc5w4CHMq-2Bu4cS5WrXT3bzwWk-3D_2vEmGfTv6NF9ysi44XFDLSmAR8EbLECDBSNjtoNhoJc7nstNZq8TQ3olFaKHjkV0JY93Dl1NCEdlSAxI-2BzElmet8Vv9K-2FhATatdwY1vybLkf2fKUlp8Hr3fnyWEFWjVV7uCGsTGZqdY6FWG1XnK9Ky47WQHzCw55lWYXrgz-2F4zCRQrIZ9nglbaTAkhmWVojtcJofNeieF-2FjylDT1DYvD8jXUyEUxTSFxTWzDMLHM-2BtBueW7uicl-2FQD9J3M3jmzhSGokoDIdAfbGbli-2F9AnzSpgd7qAzapiyx3-2B7ewGleEQNcdk3pHmo9Cy4GHhIX0UTT>
I installed the certificate and I am still being prompted for username/password. I will not accept anything including the Admin log on. Any ideas?
I am having the same issue! I installed the SSL certificate and still is not letting me get to portal. Have you had any luck?
Lisa,
when you visit the website using HTTPS does it look like you have a valid certificate?
In Google Chrome you should see a lock in the address bar, just like GeoNet has right now as you read this message.
You can click on that lock and get more information about the certificate.
I believe once we got a signed certificate we were able to login fine.
Did you get this issue resolved Lisa? We are having the same issue. Everything seems to be fine with our SSL cert. I can visit the portal site on an iPad, but when I try to login to collector it says "unknown error occurred"
Curious, but Cort, what security is used in Portal? I.e. Is it a built-in named user or windows credentials or SAML (ADFS)?
Built-in named user. I am using the initial administrator username and password to try and sign in on Collector.
Is the certificate coming from GoDaddy or is it a wildcard certificate?
Aravind
Aravind, thanks for the reply!
Not coming from GoDaddy. I'll have to check with our IT Dept to find if it is a wildcard certificate.
The cert is issued by thawte SSL CA - G2
(not sure if that says anything about it being a wildcard or not).....
Okay try the following steps:
1. Open Portal in Chrome.
2. Look at the URL, eg.
- Does it have a fully secured green with the green lock in front?
3. If so, click the green lock icon, you will get the following option. Choose "Connection".
4. Click certificate information.
5. Choose details.
6. Scroll down to Field: "Subject".
7. Look at the value of "CN" in subject. If it's: <portal-domain-name> then good. If it contains " * " in the front, it's assigned as a wildcard certificate.
No I did not get it resolved. Sorry for late response I had the flu last week
Lisa Eshelman
Sandia National Laboratory, Org 9516
CAD, GIS and Space Application Project Lead
505-844-0162
That sounds like you might have some issues with IWA? or is it a Linux setup?
I'm working through similar issues except I can get in fine (usually) but other users have issues.
It appears to be related to the security settings in Portal and IIS.
