private function hasValidMapPoints(points:Array):Boolean { var isValid:Boolean; if (points && points.length > 0) { isValid = true; for each (var point:MapPoint in points) { if (!isValidMapPoint(point)) { isValid = false; break; } } } return isValid; }
I am still hoping to figure this out. In the GeocoderComponent.mxml file, there is a function used to validate map points. Would anyone know or think it's even possible to alter this function to include a way to check for duplicate addresses? This is the only function I found that seems to the be a remotely correct starting point. private function hasValidMapPoints(points:Array):Boolean { var isValid:Boolean; if (points && points.length > 0) { isValid = true; for each (var point:MapPoint in points) { if (!isValidMapPoint(point)) { isValid = false; break; } } } return isValid; }The above code comes from line 695 in the GeocoderComponent.mxml file.
Hi Raffi,Unfortunately, I was never able to figure this out! I ended up taking the route of reworking my geocoder and creating different ones with different settings until I got the results that most aligned with what I was looking for. Due to our street centerline data inaccuracies, there are some overlaps in street ranges and in those cases, the duplicates still remained.Good luck!David
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
