I am having a problem where when I use the "Make NetCDF Raster Layers" tool to import netcdf files into ArcGIS pro, the grids are shifted by 0.01 deg. This problem causes my data to not align with each other. When I working with the output from ArcGIS else, the grids are not as expected.
Has anyone else experienced this problem? Is there something I can change in my import to prevent this shift?
Thanks for your help.
