I was working out the SQL portion and noticed that Caleb has an excellent solution!Thanks -- this is useful.Edit: here's what I was working on. I just incorporated the sql from Caleb's example...def select_Even(): mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] for lyr in arcpy.mapping.ListLayers(mxd): if lyr.name=='thelayernameintheTOC': even = [] cursor = arcpy.SearchCursor(lyr) for row in cursor: if int(row.OBJECTID) % 2 == 0: even.append(int(row.OBJECTID)) field = "OBJECTID" even_sql = ' OR '.join('%s = %s' %(field,i) for i in even) arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', even_sql) else: arcpy.AddMessage("layer not found") select_Even()
def EvenOrOdd(val): x = int(val) if x % 2 == 0: return "EVEN" else: return "ODD" msg = EvenOrOdd(6) print msg
import arcpy fc = r'G:\Data\Geodatabase\Cedar_County.gdb\JURISDICTION\CORP_LIM' oid = arcpy.Describe(fc).OIDFieldName even = [] odd = [] rows = arcpy.SearchCursor(fc) for row in rows: fid = row.getValue(oid) if fid %2 == 0: even.append(fid) else: odd.append(fid) del row, rows field = arcpy.AddFieldDelimiters(fc, oid) even_sql = ' OR '.join('%s = %s' %(field,i) for i in even) odd_sql = ' OR '.join('%s = %s' %(field,i) for i in odd) # Make Feature layers lyr = arcpy.MakeFeatureLayer_management(fc, 'Temp_layer') # Select Even arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', even_sql) # Select odd arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', odd_sql)
import arcpy fc = r'G:\Data\Geodatabase\Cedar_County.gdb\JURISDICTION\CORP_LIM' oid = arcpy.Describe(fc).OIDFieldName #Add Field to tell if even/odd arcpy.AddField_management(fc, 'Type', 'TEXT',4) rows = arcpy.UpdateCursor(fc) for row in rows: fid = row.getValue(oid) if fid %2 == 0: row.Type = 'Even' else: row.Type = 'Odd' rows.updateRow(row) del row, rows typeField = arcpy.AddFieldDelimiters(fc, 'Type') even_sql = "%s = 'Even'" %typeField odd_sql = "%s = 'Odd'" %typeField # Make Feature layers lyr = arcpy.MakeFeatureLayer_management(fc, 'Temp_layer') # Select Even arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', even_sql) # Select odd arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', odd_sql)
...Round(NumberField / 2, 0) = NumberField / 2Round(NumberField / 2, 0) <> NumberField / 2...Appending ObjectIDs into an SQL list is not a good approach if your database is very large (100K+ records), because the list will become huge and will take a long time to process (assuming it does not just fail). Plus by reading the database with a cursor you are effectively doubling the database read time, since the SelectLayerByAttribute tool will have to read the entire database again to select everything, making that approach very inefficient.
the expression should be modified to the following:Round(Round(NumberField, 0) / 2, 0) = Round(NumberField, 0) / 2Round(Round(NumberField, 0) / 2, 0) <> Round(NumberField, 0) / 2
Wow...this is pretty cool. I also vote for Richards answer.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
