Hi,Can you post the code which demonstrates the issue?CheersMike
Hi,Actually, maybe the code isn't necessary - have you set the FeatureLayer.Mode to OnDemand? (the default is Snapshot - i.e. everything up to the first 1000, or whatever the service limit is).CheersMike
Have you saved the graphic into layer and verified that it is found from the service?You can easily check that from the REST endpoint with query tool.
Hi,Are you able to share you code? It would be useful to see exactly how your app is written.CheersMike
